    Mar 2016
    48
    reverse rotation motor
    why is traxxas putting a reverse rotation motor in the trx4 whats the point? i ordered a 14 turn 550 can team broud motor but its not a reverse rotation. do i need a reverse rotation motor or can i just reverse the wires?
    Jun 2002
    284
    The stock motor is reverse rotation presumably because having the portals in each axle reverses the direction of the axles, so the easiest way to get the wheels turning the intended direction without adding more complexity elsewhere in the drivetrain is to run a reverse motor. You can run the Team Brood motor reversed as long as you keep it at 0 timing, just flip the wires (either wire the positive to the negative, or the negative to the positive, or just flip the wires at the bullet connector.
    Traxxas TRX-4 Bronco
    Mar 2016
    48
    why cant i adjust the timing once i flip the wires?
    Oct 2016
    67
    or just reverse the throttle via the transmitter? that's what i did when i swapped my tekin motor in. took all of 5 seconds to do
    Jan 2019
    94
    It can damage motors with more aggressive timing to run in reverse. That's part of the reason the typical "race" ESC does not have reverse.
