    Jan 2019
    93
    Slash 4x4 and HW SCT combo install question
    My HW SCT combo for my Slash 4x4 build came with motor leads soldered to the motor at one end and 4mm male banana plugs at the other end. OK so far.
    Instead of soldering posts, the ESC has what appear to be 4mm female banana plugs. Do those of you who have this ESC just plug the motor in at the ESC?
    Plugging in the motor this way seems like an easy way to flex the board inside the ESC, causing problems.
    Jul 2013
    Northern Norway
    846
    Yes, just plug the motor bullets straight into the ESC. After two years use I've not had a single issue with it. The board is epoxied in there and can't be "flexed". (Btw. I guess you are asking about the Ezrun Max10 SCT combo.)
    Jan 2019
    93
    Thank you - yes, ezrun max 10 SCT.
