    Mar 2019
    3
    sos!!! if I install the motor hobbywing axe540 already? thank very much
    I got question. Can I install the original traxxas bronco (the product series number is 8036) if I install the motor hobbywing axe540 already? If that is possible, can you teach me how to install? thanks
    N. Idaho... Da Sticks!
    7,447
    WELCOME TO THE FORUMS!!!!
    I don't really understand your questions...
    What is installed now (ESC/Motor), and what do you want to replace it with?
    Mar 2019
    3
    Product number 8036, is to connect to the red line of esc, I have installed the motor hobbywing axe540 2300kv, but on the hobbywing ESC, there is a red line missing, how can I install LED LIGHT SET?
    Jul 2013
    Northern Norway
    846
    Traxxas 8036 comes without the power supply, so i guess you have the 8035 (or maybe you bought the power supply separately, TRA8028).
    Anyhow, you need to get an extension with a JST plug (like the red one on the XL5HV ESC) and solder it to the battery leads on the AXE ESC, and then connect it to the light kit power supply. Do not plug the light kit directly into the receiver or the battery voltage, because the light kit operates on 3V. The light kit has to be powered by the power supply #8028.
    https://www.hobbytown.com/protek-rc-...tk-5218/p23432
    Mar 2019
    3
    If I use it, I won't solder, ok?
    (https://www.hobbytown.com/powershift...wr-053/p797416)
    Finally solved the troubles in my heart
    thank you very much.
