Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Thread: Servo for UDR
  1. #41
    Nov 2016
    25
    UDR's ESC has internal bec which is 6v, 10A. HVservo can work with 6v but shows less power and speed. Servo can consume up to 8A at peak moments. But there is another power consumers in the model. So the load for internal bec is high, it can be overheated and damaged. That's why it is better to use external bec that is more then 8A and has high voltage output 7.4v. Servo will work faster with more torque and with less load on the ESC with internal bec.
  2. #42
    Nov 2016
    25
    I use YPG 20A SBEC with dual output for servo and cooling fan. It set for 7.4v.
  3. #43
    Feb 2019
    57
    Quote Originally Posted by Mpress2570 View Post
    Doing a little more research but your the reefs rc is what Iím leaning more toward now.
    Definetely do research on all suggestions here - I've had no problems with this Triple 4.
    Sent from my SM-G965U using Tapatalk
  4. #44
    Sep 2015
    22
    Quote Originally Posted by Scoobarooo View Post
    Thatís actually what I ended up ordering.
  5. #45
    Feb 2019
    57
    Ah, very good! You'll have plenty of luck with it.
  6. #46
    Sep 2015
    22
    Now just have to read into installing it and setting it up properly
  7. #47
    Feb 2019
    57
    Plug and play. Took me no more than 5 minutes
  8. #48
    Sep 2015
    22
    What about getting the horn on there properly? Iíd imagine turning the truck on with the servo disconnected then installing it with the wheels pointed straight? Iíve only had a slash and 4tec before my udr and both of those never had servo issues.
  9. #49
    Feb 2019
    57
    Yes. Once you plug in the reefs servo, turn the truck on, let is straighten out and put the servo horn on correctly then bolt everything down and your done.
    Sent from my S9+ using Tapatalk
  10. #50
    Sep 2015
    22
    Awesome thanks
  11. #51
    RC Champion akrimmel's Avatar
    SAINT CHARLES, MO
    2,567
    After my 1230sg has been sticking and glitchy I ordered a
    Power HD WP-23KG Waterproof, price wise is half the cost of the savox 1230sg. I like to rinse my truck down after bashing
    and track bashes, if it works great otherwise I'm only out $40$
    U.D.R. IN FULL MOD MODE
    MMX SUMMIT 2200KV!
