    RC Champion akrimmel's Avatar
    SAINT CHARLES, MO
    2,568
    An o.g. Summit revisited.
    What she used to look like:
    AND NOW:
    U.D.R. IN FULL MOD MODE
    MMX SUMMIT 2200KV!
    Sep 2013
    France
    110
    Nice !! the body looks awesome, do you paint it ?
    but....still a gray chassis
    "souvent fauché toujours marteau !"
    SAINT CHARLES, MO
    2,568
    Have to give props to PITDAWGHYDRO.COM for my new body, 2017 Ford Raptor SVT proline body. MMX esc, CC 2200kv, replaced all 45bearings from the stock Abec-1 to Abec-3, 2000k shock oil all around, 100,000k differential front and rear, Proline Rock Rage tires on F-11wheels 1/2offset.
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    Quote Originally Posted by The Dude View Post
    It was hydro dipped.
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    All that is left it to set the toe and camber in the front and it's 100%, but I got a new toy.....
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    Quick up close of wheels and tire, I painted everything you see on the wheel and tire.
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    Its basically all RPM'd out, traxxas alumumin tubes, traxxas center and rear driveshafts, with HR Front/rear CVD HD Steel Universal Driveshafts. Now just small tweaks at the track I hope.
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    On the first test drive it lasted all of about 34seconds due to the fact I had balanced the tires with clay like normal. The front left wheel was perfectly balanced so it didn't need any, front right needed alot, I guess do to the right having so much more weight, when it drove it looked like I had hydraulics on the front. Went to LHS and they said the shafts needed shimming, 3 washers behind each wheel nut stiffened it up as well, applied some power while holding it in the air and no tire wobble. So with that done, now I can try again for the test drive and se how it handles.
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,568
    So it still shakes in the front after turning, so u believe that I have to take the clay out of the rear tires, also put 40wt oil in shocks, forgot I gave 2k wt in there from when it was brushed.
    Sent from my SM-G935T using Tapatalk
    MMX SUMMIT 2200KV!
