Results 1 to 2 of 2
    Jan 2009
    Great Britain
    1,038
    Transmission servo
    So after 15 months my transmission servo packed up. No big deal. It lasted well. So I installed my spare amd the throw is massively different. The servo is fighting against the pin to force it in! I've obviously set it so that in high its where it should be but when I change to low it wants to go further. Amy ideas?
    2wd Slash VXL, 2wd Slash 9t , E Maxx 2200kv ,Trx4
    Jul 2013
    Northern Norway
    878
    Try moving the servo saver horn one or two notches in the opposite direction, so that the servo "overshoots" the same amount in both directions.
    To solve the problem permanently, I can highly recommend this endpoint adjuster (I use it on all micro servos):
    https://modelradioworkshop.co.uk/sho...oint-adjuster/
    It's even a UK company...
