Results 1 to 16 of 16
    Mar 2019
    19
    Best batteries and charger for E Revo 2.0?
    I am completely ignorant when it comes to Electric RC cars and batteries I've heard the traxxas batteries for the E Revo 2.0 isn't that great could someone link me to some good batteries and a charger that will work with the Revo 2.0?
    Dec 2003
    Dekalb, IL
    2,513
    Not sure that kind of thread can be posted here...
    Expert rigging at it's best!
    Mar 2019
    19
    Why? I'm asking about batteries for the E Revo 2.0 and this is the E Revo forum
    Apr 2018
    1,031
    As far as batteries go either the Traxxas ones or SMC. Traxxas has a pretty good warranty on their batteries. SMC batteries as pretty good as well and are highly recommend on this forum. As far as chargers go, Iíll let someone else post about what they use as there are just way too many choices. Just depends on how much you are willing to spend and how fast and how many batteries you want to charge at the same time.
    Feb 2019
    Midland, Texas
    49
    SMC batteries all the way, I have a Hitec X2 black edition charger. I really like it but to charge SMC 7200 3s lipos it takes 2 hrs to charge, smaller batteries will be faster.
    Mar 2019
    I am about to buy a e revo 2.0 and i want to know if this battery fits?
    https://www.amainhobbies.com/common-...8aAgnSEALw_wcB
    RC Champion RICK DIZZLE's Avatar
    Sierra Vista, AZ
    1,213
    I'm running SMC 7200s as well...was having same charge times as RocBoy on my Venom Duo Pro. I bought the Hota D6 DC charger and used my P350 power supply to power it. Now I charge both packs simultaneously in 33-35 minutes. Like mentioned...smaller MAH packs will take less time...the 7200s are beasts.
    Dec 2003
    Dekalb, IL
    2,513
    Quote Originally Posted by brycecranmore View Post
    These should:
    https://www.smc-racing.net/index.php...product_id=506
    Length 160mm / 6.30in
    Width 46mm / 1.81in
    Height 29mm / 1.14n
    These are the same size as the 2S 7400's I run in my ERBEv1, lower MAH than the above ones:
    https://www.smc-racing.net/index.php...product_id=463
    Sierra Vista, AZ
    1,213
    Those 7200s that Olds97 posted are what myself and RocBoy are running and fit...they are big and fill the entire battery compartment, but fit the E Revo 2.0.
    Dec 2015
    St. Peters, MO
    3,453
    Just be careful pulling them out once they swell a little itll make em tight in there and watch balance leads tuck in nicely oh and dremel or open up bigger where batt wires come out of batt compartment. Here's my set up and old picture of batts, now I have 5 more lol.
    Dec 2018
    46
    Inviato dal mio SM-A310F utilizzando Tapatalk
    Mar 2019
    19
    If I were to buy the Traxxas batteries does anyone know what kind of run times I would get?
    Sierra Vista, AZ
    1,213
    Anyone running SMC 3s 5400mah packs and if so what kinda run times are you seeing have 7200mah now and they are great just big and heavy...for speed runs wondering how the 5400mah packs would do?
    Apr 2019
    Any recommendations for a charger that will simultaneously charge two batteries?
    Apr 2019
    My battery and charger choice for the E-Revo 2.0
    Quote Originally Posted by Pek75 View Post
    Reedy 1216c2 is an awesome charger.
    https://www.amainhobbies.com/reedy-1...BoCjTUQAvD_BwE
    And these Ovonic batteries rock and are at a great price!
    https://www.ebay.com/itm/Ovonic-5500...e/283414297052
    Dec 2003
    Dekalb, IL
    2,513
    Depends on what else you may want to charge later on. If you think your going to stick with 3S/5000mah packs for a long time, a 2x100W/2x10A charger would cover it. But if you think your going to run 4S or 6S in something, you have to go bigger or you waste your money now.
    The hitec D7 is a fairly capable 2x200W/20A AC/DC charger.
    If you think may end up exceeding that, the you may want to go with DC chargers and get a capable PSU.
    https://www.amainhobbies.com/hitec-x...c44239/p481677
    http://lipoconnectionsolutions.com/D...D2417404MM.htm
    There are quite a few options out there. Just depends on what you want to spend.
    I started electric with the ERBEv1 and I ran 2x2S in it. My dynamite 4x100w/10A charger worked well for that. Now I'm running 3S in other trucks and it does fine charging 4x5000mah 3S packs at 1C and peaks out when I crank it up to 10A to try to charge at 2C because it hits the wattage limit. Still charges fine, but throttles itself back to 8.9A or so because it would need 111watts to charge those at 2C.
    I also have the hitec D7 at home I use for my 7200mah 3S packs.
    I have a HRC150AC/DC duo which has similar specs to that reedy charger mentioned up above, 2x150W/12A, I keep it in my car for field charging.
