So far I’ve fitted
RPM front bumper
RPM trailing arms and skids
RPM front upper arms
Traxxas 8542x rear upper links
All the above are easily available at most hobby stores or online
Other parts I’ve fitted
GPM anti rollbar links
https://www.ebay.co.uk/itm/4pcs-Stee...72.m2749.l2649
Alloy rear axle bearing blocks
https://www.ebay.co.uk/itm/Alloy-Rea...72.m2749.l2649
FOX shock stickers
https://www.ebay.co.uk/itm/4pcs-Shoc...72.m2749.l2649
Alloy brake disc/hex’s
https://www.ebay.co.uk/itm/1-7-RC-Me...72.m2749.l2649
Shock leak prevention kit
https://www.ebay.co.uk/itm/Shock-Abs...72.m2749.l2649
Mud flap kit
https://www.ebay.co.uk/itm/RC-1-7-Ru...72.m2749.l2649
How's the aluminum rear end working?
U.D.R. IN FULL MOD MODE
MMX SUMMIT 2200KV!
Only fitted it yesterday, I’m impressed with the fit and finish, the gear mesh is perfect and it looks the nuts
Your undercarriage still looks unbashed, or u just had it detailed, lol. I just rinse mine with the hose.
MMX SUMMIT 2200KV!
I only run on grass and soft dirt, so my RC’s don’t get beat up, the setting are on the app to change the colours/gauges/layout, that’s a old screenshot, I’ve now added another sensor so I can read motor temps and BEC voltage
I touch the wrench by the icons, but no option to change colors
MMX SUMMIT 2200KV!
I had to delete the gauge first, then once I clicked where it was I had different options of color or not. Thanks.
MMX SUMMIT 2200KV!
If I go to a 47t spur, that will increase the speed or torque, anyone. I have the 47t spur and 31t pinion the combo should increase the speed right?
MMX SUMMIT 2200KV!
Smaller spur and/or a bigger pinion = more speed
Bigger spur and/or a smaller pinion = less speed and more torque
Nothing, 6s and stock gearing is around 50mph
Reason I asked I was only getting 33mph after I put the 31t pinion on that 4s 9000, but I had 2 issues from preventing higher speeds, limiting strap hardware gone and loose wheel nuts.
MMX SUMMIT 2200KV!
My mate gets 38mph out of his on 4s hes running a different spur and pinion, I’ll ask him what he changed it to
Sounds good, should have mine back up this afternoon and have more info.
MMX SUMMIT 2200KV!
He’s running a 34t pinion and the stock spur for 38mph according to the Link App
Hmm, going from 27t to 31t I should get a little extra once I fix those 2 things, when my upgraded driveshafts show up I will take the 51t spur out and put in the 47t spur I should get close to low 40ish with the my 4s I would hope.
MMX SUMMIT 2200KV!
very nice AJ.
Do you have plans to get the vitavon wheels?
do you have a link to where I can purchase the dhawk front shaft?
CheersIm not sold on the wheels tbh, I had alloy beadlocks on a Yeti XL and they were more trouble than they were worth.... So I’ll wait for some proper feedback before committing to them, I’ve found beadlocks are great on something slower, but the extra weight isn’t great for anything fast.
I bought the front shaft from the Dhawk eBay shop, they also sell them on Amazon
https://www.ebay.com/itm/CNC-Aluminu...8AAOSwZOBbgn2x
thanks AJ. I was looking to just get the gpm front shaft but the dhawk looks very nice from your photos
Cool, I would pick Dhawk parts over GPM every time
It’s pretty much the same diameter, but a little longer, I’ll stick a picture on my build thread on MSUK and I thought the name look familiar![]()
Thats better, now go before the Traxxas mods catch you![]()
