Results 1 to 13 of 13
    Apr 2019
    5
    Stability Management working with other radios on X Maxx 8S?
    Hello everyone! I discovered the 8S and it's intriguing me a lot! But I prefer the feeling of a stick radio instead the "gun" type. There is a chance to control X Maxx from different radio transmitter without loose the stability function?
    13,529
    TSM is in the receiver. Remove the receiver and remove TSM. Traxxas receivers work with Traxxas transmitters.
    Apr 2019
    5
    Thanks. I planning to remove all electronics from traxxas radio and put everithing in a stick radio. Brutal but definitive. Just need to adapt two potentiometers and place some buttons with right holes. Yes, I really hate gun trasmitter...
    Dec 2001
    Everywhere man
    1,222
    Quote Originally Posted by BeautyFool View Post
    My buddies and I much prefer without TSM, you just gotta drive the vehicle.
    Yes, but needs knob assigned to the TSM function, I always dial mine down to zero or remove the rx.
    Apr 2019
    5
    Quote Originally Posted by Natedog View Post
    Maybe I don't need TSM, it's work only for corners or also during jumps to hit ground safely?
    15,211
    It's basically a gyro to help control understeer
    Ya can't polish fertilizer...
    Apr 2019
    5
    Thanks!
    At the end, nothing I really need. I misunderstand from the official video there's more with stabilization when you do high jumps. Luckly for me is only for cornering. I can replace receiver easily and use my favourite trasmitter.
    Jun 2017
    MA
    272
    its a LOT more then this.
    it will keep the truck going straight if your controller wheel is straight.
    its reactive to yar.
    if the truck hits a bump and pitches sideways TSM will correct it and keep the truck on track.
    yes it uses a giro to sense the movement of the truck but the logic used to change steering angle based on yar is quite complex.
    here is an example:
    set your steering trim hard left (or right) and turn on tsm to at least 50% on.
    the truck will track straight at speed, no matter how off center your steering trim is set.
    try it.
    Jan 2019
    46
    A lot of people say that it also increases the risk of having issues with the servo as it makes it working a lot more, especially with the stock one.
    Jan 2019
    46
    I think it should run with a multiprotol extension of a stick radio. I fly drone racers and I use this kind of system:
    [81,22 13% OFF]Jumper T12 OpenTX 16CH Radio Transmitter with JP4-in-1 Multi-protocol RF Module for Frsky JR Flysky RC Parts from Toys Hobbies and Robot on banggood.com
    https://banggood.app.link/XPVzb9BxBV
    Apr 2019
    5
    Quote Originally Posted by Yannkee75 View Post
    Seems a good option. Can I block the axes with this radio? With your drone you use all 4 axes, for a car I just need two
    Jan 2019
    46
    We usually use more than 8 channels but 4 are the minimum to fly and control the quadcopter. You will be able to assign the channels as you need. Depends on the receiver =)
    May 2016
    10
    I feel U bro : I can't drive with gun type transmitter !
    https://forums.traxxas.com/showthrea...ight=futatraxx
    I updated to Arduino since tho ; way easier to implement, I even added a lot of functionalities
