    Oct 2018
    Tennessee
    66
    Question Is this a good castle setup for rustler 4x4?
    So Iím back again with another question. I currently have a Kinexsis 3000kv brushless system in my rustler 4x4, itís a 550 can sized motor. It has plenty of torque and speed. Itís a good system for 70 bucks. But I want more. And I want to give castle a try. As the title says, would this link be a good system for rustler 4x4?
    http://www.castlecreations.com/en/si...or-010-0164-07
    Any and all suggestions would be great. Thanks
    Nov 2018
    401
    it can be run on a 2s LiPo but will be very slow. It is a cooling running torque animal for lighter 1/10th scale 2WD stadium trucks and buggies running on a 3s LiPo. This is directly copied. Strictly 3s runs. Rustler 4x4 vxl is a rather heavy vechicle, so I think the 2400 kv is a great option. It will work well, just gear it up. I think it was tmbold or someone else on this forum who hit 100+ mph with that motor geared up.
    Oct 2018
    Tennessee
    66
    Yeah I wasn’t entirely sure about this system and I’ve read quite a few threads with others saying a 2400kv castle motor is good for the extra weight the rustler 4x4 has. I think mine is roughly 5.8 lbs with a 3s 4000mah lipo. So it’s a fatty for a stadium truck lol. So Luke, this castle system would be okay? I don’t have any previous castle experience and do t want to buy a brushless system that isn’t what I’m looking for. Thanks for the help!
    13,318
    A 5.12lbs (2.32 kg) Rustler 4x4 is rather heavy? Compared to what?
    Slash 4x4 Platinum & Ultimate: 80.4oz (2.28kg/5.025lb)
    Stampede 4x4 VXL: 89.64 oz (2.54kg/5.6025lb)
    Slash 4x4 VXL: 93.1oz (2.64kg/5.819lb)
    Quote Originally Posted by Rocketzx1 View Post
    The limitation of the Sidewinder 4/2400kv combo is the ESC; you'll get the same motor with the Mamba X but more adjustability with the ESC. The 2400 is a very good motor for the weight and drivetrain resistance of a 4wd. Give Castle a call and verify if they recommend the Sidewinder with the Rustler 4x4 and while you are at it find out why a majority of their products are out of stock/backorder/not available.
    Jun 2014
    Southern California
    7,435
    Double G is talking about this combo:
    http://www.castlecreations.com/en/ma...bo-010-0160-01
    Oct 2018
    Tennessee
    66
    Okay sorry for calling the rustler 4x4 heavy. I was going off of how much my 4x4 monster truck weighs, it’s about a pound less than the rustler 4x4 with a 3s 4000mah battery. I ask these questions because the last time I had an rc car was when the gold pan rc10ts were new, and they were awesome. I also had an old tamiya hornet. I’m new to the brushless systems, I didn’t even know about them until 2 years ago >.< So I guess you could say I’m new to the hobby again lol I appreciate all you guys in setting me straight. Thank you
    RC Turnbuckle Jr. vxlrocket's Avatar
    Dec 2007
    Manassas, Va
    7,179
    there are other things that become problematic once you go to a 2400 motor though...no matter the esc. You're going to start twisting driveshafts from the torque...there's almost no way to get around that unless you run a 1405 sized motor on 2S.
    even the velineons twist them on 3S eventually. My advise is to get yourself the tekno driveshaft kits or the mip x-duty cvds. that'll allow you to run motors that are a lot more torquey without hurting the drive train.
    My first 2 upgrades on any slash or shash based platform is the mip cvds and the 17mm wheel adapters.
    then you might wanna look into a gen 1 e-revo slipper setup with aluminum pads. throttle heavy drivers seem to burn the carbon ones like matches. I did.
    After that...perhaps a good 4s battery to go with it. then you're gonna be looking at a beast of a truck.
    One mans garbage is another mans ungarbage" -Ricky
    Nov 2018
    401
    Quote Originally Posted by vxlrocket View Post
    Good idea about those driveshafts. It is essential to have a failsafe cheap/weakish spot. That way if too much power goes through, a cheap and easy to service part is broken, instead of your diffs. My failsafe is a plastic spur gear. I have aliminum wheel hexes, tekno m6's and metal diffs, but a plastic spur gear.
    RC Qualifier tmbold's Avatar
    Oct 2014
    Louisiana
    346
    I put the castle 1415 2400kv with the mamba x, it is a beast. You will need to run 3s 5000mah + with this set up. I prefer 4s.
