Results 1 to 10 of 10
    Feb 2019
    42
    Question traxxas loctite problem
    i have blue threadlock on my mip xduty screws and now when one came apart i need to rebuild it now i cant remove them its really tight how do you loosen them thanks
    Aug 2015
    482
    Quote Originally Posted by lukebush16 View Post
    A small amount of heat helps, i carefully use a lighter, or a heat gun or hair dryer works.
    Sent from my VS996 using Tapatalk
    Apr 2015
    US, Nj
    72
    Heat, thatís the easies way to break its hold. Just be careful around plastics. Just use a small hobby torch, nothing to big.
    Victoria B.C Canada
    5,621
    I use a soldering gun to warm the screw
    Sent from my SM-G930W8 using Tapatalk
    Mountains cant stop me
    they have tried
    Jun 2017
    381
    One more vote for soldering gun.
    RC Qualifier Trentbaby65's Avatar
    Feb 2017
    438
    Sent from my SM-J530Y using Tapatalk
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,175
    A good idea except that the fastener isn't what you want to get heated to release the thread lock since an expanding fastener only gets tighter. You want to heat the outside so it expands and the fastener stays small and is easy to remove.
    Feb 2017
    438
    Quote Originally Posted by zedorda View Post
    You're not trying to expand or contract anything.
    Heat liquifies loctite.
    Problem solved.
    Sep 2015
    S.E. Michigan
    1,175
    Quote Originally Posted by Trentbaby65 View Post
    Problem solved.
    I believe you are thinking about Loctite RED which melts under heat but BLUE is a different chemical composite and doesn't melt but may soften some. Heat works universally to loosen fasteners because of differential thermal expansion.
    Feb 2017
    438
    Ok, I agree. It softens the blue loctite lessening its hold on the threads.
    Again. Problem solved.
