Results 1 to 28 of 28
    Mar 2019
    41
    Results from stampede motor swap
    So I burned up my vxl 3500kv in my stamped and installed the hobbystar 3660 3300kv motor. I'm impressed with how cool it stays after long heavy throttle 2s runs but it doesn't have the torque or wheelie ability of the stock motor. Maybe I should add a couple teeth on the pinion gear but don't want to cause heat issues. I'm using integy heat sink with dual fans. I melted down one motor quickly trying to make this one last
    RC Qualifier zedorda's Avatar
    Sep 2015
    S.E. Michigan
    823
    The lack of the same power is mostly because the stock ESC doesn't deliver the punch that the 3660 can handle. If you add teeth I bet the ESC gets hotter first.
    Mar 2019
    41
    I see your point there with the esc getting hot but as far as no punch I'm not sure I understand. The stock esc is a 200amp with Max of 320 amp and the hobbywing recommended esc was 150am tiny little thing
    Sep 2015
    S.E. Michigan
    823
    The specs on Traxxas ESCs are alittle exaggerated. In my experience I would compare the VXL-3 to most 80-120amp ESCs but also don't exactly deliver much on launch.
    Apr 2015
    749
    What is your gearing right now with the new 3300 KV?
    Mar 2019
    41
    11/54 stock vxl gearing
    Mar 2019
    41
    I know with the stock motor and esc on 2s it would wheelie and flip on it's roof on launch and now it won't lift the front tires off the ground in the slightest
    Sep 2015
    S.E. Michigan
    823
    I would try the 15t speed pinion and see what happens.
    Oct 2016
    4,026
    The stock esc is nowhere near a 200amp esc. Escís that run 1/5 scale trucks are in that range. Any chance youíre in training mode?
    Mar 2019
    41
    Mar 2019
    41
    It isn't in training mode. It runs fast, almost to fast to control on 3s at 3/4 throttle but nothing I do will make it wheelie. Motor wraps out quick, also having trouble getting it to flip off the ramp I built. Plenty of power just not on low end
    Mar 2019
    41
    @gripdog7205
    Maybe the amp ratings aren't that high on the vxl 3s but that's what traxxas claims they are. I'm kind of a newbie to electric rc so I can only go by what I read on the product websites. I need little more exp. Before I know what's bs and what's fact lol
    Mar 2019
    41
    I do know when I burned up the stock motor I was running in high grass and it stopped and made a high pitched noise so I could have damaged the slipper clutch as well but it all looks to be inyact
    Mar 2019
    41
    Oops I meant intact
    Oct 2016
    4,026
    Quote Originally Posted by dubyab14 View Post
    Is the clutch slipping?
    Mar 2019
    41
    I was kinda thinking that since I was running in high grass when I got the burned smell and the original motor started going out
    Oct 2016
    4,026
    The high pitch squeal is a dead giveaway.
    Mar 2019
    41
    Thanks I'll remember that. Like I said I'm a newbie. So then that clutch is adjustable if I haven't destroyed it. I may have to look into a new one or new pads possibly
    Mar 2019
    41
    Well I pulled the cover off and tightened the clutch and we have lift off once again. I wasn't hearing much squeal after the motor swap but I guess just enough to not go full power to the wheels
    Sep 2015
    S.E. Michigan
    823
    Nice it was an easy fix, grats.
    Mar 2019
    41
    thanks, yep easy fix this time but lord knows my driving will cause more issues guaranteed.
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    387
    Ha ha! Hopefully not soon so you can bash peacefully...
    I like free stuff!
    Dec 2003
    Dekalb, IL
    2,192
    I'm running that same motor now in my converted ejato with the vxl-3s esc on 3S. I haven't had a chance to run it much yet. It replaced a castle 3800kv, which was pretty "soft" in the torque department. My traxxas 3500 burned up shortly after I started running 3S. Wasn't running too hot or anything, just died on me out of the blue. It came out of my stampede 4x4 which I bought used, so I don't know how well it was cared for.
    I switched to the 3660/3200kv motor in hopes that it runs a bit cooler than the castle 3800kv did. The 3800 was ok when I was just running 2S, but I recently started running 3S and it wasn't too happy about that.
    Expert rigging at it's best!
    Apr 2018
    Downriver,Michigan
    129
    So how do you like the hobbystar 3660 3300kv now that you have your clutch fixed?
    Mar 2019
    41
    i love it. rips as hard if not harder than stock and hasnt let me down yet
    Mar 2019
    41
    needing a good set of axles though. i seem to destroy even the integy steel upgrades
    Oct 2016
    4,026
    I use Tekno M6ís. I love them. Strong and light.
    Jun 2019
    7
    i'm i right to say 15 teeth would be a lot more than before ?
    2s with 3500kv = 25 900rpm x 11/54T = 5276 RPM at the shaft
    2s with 3300kv = 24 420rpm x 11/54T = 4975 and with 15/54 it would be 6783 RPM at the drive shaft ?
    So 1.28x faster and 1.28 more torque request thru the ESC amps than it was with factory motor ?
