Results 1 to 16 of 16
    May 2017
    332
    Reck-Ralph slsh4 build/maintain
    So this is my slash I got used, supper sweet hop ups, 2200kv system, mips, clutch upgrade 17mm adapters. Great rig. But needs some love. I run 4s on this only.
    One of my biggest problems is I am specifically roasting the back left bearings, like Disintegrating them. My thought is that there is no washer's at all around any of the bearings. It's just the bearings hub and axle then tires nothing in between to space them out.
    Thx for any of the help.
    Sent from my SM-G950U using Tapatalk
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,109
    There is supposed to be 2 ball bearing in that hub carrier. Unless it was actually running bushings. Either way I would replace the rear hub carriers and new ball bearings.
    Amains has them.
    Hub Carriers:
    https://www.amainhobbies.com/traxxas...52x/p48959?r=0
    Bearings:
    https://www.amainhobbies.com/traxxas...YaAsTvEALw_wcB
    May 2017
    332
    Quote Originally Posted by zedorda View Post
    The thing is though, the carriers r fine, they got a little shaved from the mips, but that's it. I'll give it a try. Think I got some rpm carriers laying around.
    Sep 2015
    S.E. Michigan
    1,109
    Quote Originally Posted by Gdude1057 View Post
    If the carrieras are salvageable just toss some new bearings in and see how it goes.
    Sep 2015
    S.E. Michigan
    1,109
    I like that body you know which one it is from Pro-Line?
    May 2017
    332
    Not off the top of my head, it's their rally body, just type in rally proline should come up. it is awesome, the guy before me did a horrible paint job. Uh well. I did put new bearings in, that's from new bearing in one run... crazy uh?!
    Sep 2015
    S.E. Michigan
    1,109
    Holy cow just one run and you toasted the bearings that bad?! Yeah there is definitely more going on. First possible culprit imo are the MIPs. MIP X-Duty axles have a limited suspension travel capability and the Slash 4x4 can be setup to go beyond that limit. Might want to check for possible binding at suspension travel extremes.
    53
    I know this because i just rebuilt my mips the rear has a spacer in between the bearings, thatís probably why you are roasting them.....if thatís not it I donít know what it is
    Sent from my iPad using Tapatalk Pro
    Jun 2017
    364
    ^^ This
    Check for spacers on rear mips.
    May 2017
    332
    Quote Originally Posted by The Borderdog View Post
    Ok ya, that pic explains it all! I am missing those spacers... gur! If anyone knows the part number awesome!
    Thx for the speedy responses!
    May 2017
    332
    I am going to try part number 1985# from traxxas, they r just small washers to protect the bearings but I dont have em on so will see. Hopefully get everything friday...
    Jun 2014
    Southern California
    7,573
    See their webpage for a list of parts and give them a call. Their customer service is great!
    Click on the "What's Included" tab:
    https://www.miponline.com/MIP-X-Duty...-Rustler-18140
    Customer service:
    https://www.miponline.com/Customer-Service-Tech-Help
    Good luck!
    RC Competitor T-N-T's Avatar
    Feb 2019
    90
    I might have a pair of spacers. I believe they came with the MIP 17mm hub adapters and I already had them from my axle shafts.
    Slash Ultimate, Slash 2wd, TRX-4 Defender & Sport
    53
    Quote Originally Posted by T-N-T View Post
    This is true....however I donít think Iíve seen them sold separately...I would go with this offer
    Jun 2017
    364
    Parts numbers for MIP spacers are 10119 and 10127.
    20,527
    Please confine Support requests to Traxxas products. Thanks! ksb51rl
    Alt-248 on the number pad = į
