    The Netherlands
    181
    High-Voltage Power Amplifier with 'normal' led lights?
    I like the concept of the High-Voltage Power Amplifier providing 'clean' and dedicated power for lighting, and moreover the ability to control its output channels remotely via the Traxxas Link app.
    However, I also do like the led lighting I already have installed in the front and rear, consisting of 6V leds (custom solution by murat rc from Poland).
    So I was wondering if I could combine those two, provided that all the switching and controlling is done inside the Power Amplifier only.
    In that case it would (theoretically) work to isolate the positive and negative from one of those four (ABCD) channels, and have a connector that fits in there.
    But most important: you'd need to know the output voltage of the Power Amplifier, and since it's a High-Voltage" one, I am afraid it's more than 6V, and that would fry my installed murat rc leds.
    I hope someone can tell me if there's just a simple positive and negative pin in A, B, C and D to use, and what the output voltage is.
    Thanks in advance!
    B/R JEREMY.
    RCblog.nl Summit●ERevo2●X-MAXX●MAXX
    Eastern Shore, Maryland
    4,174
    I'd keep both separate. If I couldn't do that, then I'd use one or the other.
    Nov 2015
    63
    Hi anyone resolved this question? I too am thinking about adding the amp to power my current murat rc lights. Other option is to add a bec to reduce the lipo voltage and connect the lights to a remote control box, but where is the best place to tap into the current. I also want to add a brake light feature.
    Sent from my HUAWEI P8max using Tapatalk
    Jan 2020
    Hey guys, new to the forum, I was also looking for the voltage output but couldn't find anything online. So I tested it with a multi-meter. I got 14 volts. I have a set of led strip lights ordered for underglow, It says operating voltage is 9 - 15 volts. I'll try plugging them into the spare slot on the amplifier and let you know how it goes!
    Dec 2015
    St. Peters, MO
    3,453
    Quote Originally Posted by Streetthunder View Post
    They have led kits that run off rx voltage and the throttle and steering gives you blinkers and brake lights. I'm not understanding what OP or your wanting to do or what that amp is/does but if wanting lights with braking and blinker features no need to reinvent the wheel just buy a led kit with those options in it. Their like $25. I have a video in stampede section of working light kit. Or just make your own battery tap if want brighter leds than the stock rx voltage which I've done on speedrunner for strip of leds to light up under whole body.
    Just one more rc, then I'm done.
    Jan 2020
    Quote Originally Posted by Get rekt View Post
    Hey Hi , that is great info !!!, I would like to ask you , on the High Voltage Power Amplifier each channel has 3 pins ,the color are from left to right is black black and blue what pins do you got 14V ???? Do you got diffrent reading of Volts with the next pin of the same channel example ( black and black ) ( blue and black ) ( blue and the ather black ) ?? And last question is the Blue wire the Positive ,and the Black the Negative ???, Thank You
    Oct 2018
    Tennessee
    211
    Quote Originally Posted by Briber View Post
    They want to power LED lights and want to know if they can use the power amplifier Traxxas makes to power them, or if itís really just for Traxxas made LEDs and a bad idea to use it with the other LEDs.
    OP, I would suggest finding 14v+ LEDs and using the power amplifier if thatís what you want to do. Itís used on the UDR and the new MAXX, can also be used on the XMAXX with the Traxxas made LED light kit.
