Results 1 to 21 of 21
Thread: Which Bearings?
    Jan 2019
    [Typewriter noises] . . . Somewhere in the Eastwest . . .
    200
    Which Bearings?
    I've already established the size and that bearings are an upgrade, so which bearings should I get? Ceramic or metal (and what type of metal), and what sheilds? Also, what brand?
    Thank you all!
    May 2018
    North Florida
    25
    traxxas sells bearings, I think that for the size you need they sell the ones with metal casings that go in the motor and also the ones with the rubber casing. I would just go with rubber, part #5116. You can buy on amazon or somewhere else if you want more than just 2.
    RC Qualifier Synnergy's Avatar
    Jun 2017
    Orygun
    910
    Quote Originally Posted by Is_It_Broken? View Post
    Thank you all!
    Here's a good vid talking about bearings in the tranny. I put ceramic bearings in the last tranny I built...kind of expensive...there are a lot of different manufacturers of ceramic, I went with protek.
    https://www.youtube.com/watch?v=4dzP99OO7UI
    MTFBWY
    Jan 2019
    200
    I am talking about in the Hub carriers, because I do not want to open up the transmission unless necessary. I am a basher on a budget, so expensive is probably not the right way to go. Traxxas bearings seem to be very expensive to me oh, so are there any other recommended brands?
    Jan 2019
    200
    All right, I'm gonna simplify this.
    1. What type of metal bearings should I use?
    2. What shields should I use: rubber, metal, plastic, or some sort of combo?
    3. My rustler claims it has full ball bearings in the trans. Do I need to replace those when I replace the bushings at the wheel?
    Oct 2018
    68
    1. Rubber
    2. I like fast Eddie's bearing. I have them in my brushless wraith for almost 3 years now, I do clean and repack with marine grease every 6 to 12 months. I also have them in 2 ecx circuits, same as a 2wd rustler, for a little over a year, and I never touched them, and they still are doing great.
    3. Probably not needed but not a bad idea to do so
    Edit: 1 and 2 are swapped from your questions
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Jan 2018
    483
    For a casual basher, I'd just pick up a really cheap pack of ball bearings from China. https://www.ebay.com/itm/MR110pc-MR1...EAAOS***9ZPk08 They don't seem to be the strongest bearings, but they're so cheap, and since it's only a basher, you'll be fine.
    Jan 2019
    200
    I found a site called Avid that sells bearings for a dollar each. Does anyone have any experience with them? Are they good quality?
    Also, should I get stainless steel bearings?
    RC_N3RD, I don't want to spend money on something that won't hold up.
    Aug 2015
    482
    Avid is a very good brand, i would recommend buying a complete set for your particular car then you will have those bearings you will need in the future. You're looking at 8 minimum to do front and rear hubs alone. Stainless is the way to go, plain steel ( if they're even available) would rust easy with any moisture.
    Jan 2019
    200
    I stumbled across a company called boca that has bearings for similar prices that avid has. Which company is better?
    Jan 2019
    94
    Boca is well known for high quality ceramic bearings.
    I would assume - but I have never used them - that their stainless steel sealed bearings would be good, too. That said, it is entirely possible that they are the exact same bearings from the same plant that others sell.
    Sep 2012
    Hammonton Nj
    735
    avid , have used them for 5 years, revolutions and cheap
    Jan 2019
    200
    OK. I went through & did some research and found that avid only uses chromium steel in their bearings, so I think I will go with boca for the rust proof stainless steel. Thank you all for your help!
    Aug 2015
    482
    Chromium steel is "stainless steel"
    Jan 2019
    200
    Well, then I will get whichever brand is less expensive.
    Thanks, everyone!
    Jan 2019
    200
    Do I need to have shims to use bearings?
    If I do what shims would you recommend?
    Jan 2019
    200
    Um, yes or no?
    Aug 2015
    482
    Um, yes or no?
    Just the fiber ones (#1985) shown on the exploded view parts list.
    Jan 2019
    200
    So yes, they are necessary (is that spelled correctly?)?
    Thank you for the part number.
    Aug 2015
    482
    Yes, sometimes I use two to take up excessive play.
    Jan 2019
    200
    Thank you very much!
