    Jan 2019
    Minnesota
    51
    Front wheel drive rustler 4x4
    hey guys, yesterday I was driving my rustler 4x4 vxl around and it just switched to front wheel drive only. There were no bad sounds and the truck seemed to be running fine.
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    412
    Sounds like you broke something in the rear, open it up and see what's broken...
    I like free stuff!
    Dec 2003
    Dekalb, IL
    2,659
    Could have lost a rear slider pin. Although, that's usually pretty obvious as the inside cup of the axle falls off the diff and flops around. Could have also sheared a wheel hex pin or something inside the diff.
    Expert rigging at it's best!
    Nov 2018
    402
    I think it is what olds97 lss said. This happened to me also. If it was in the diff, I would think that it would make noise... also check to make sure that you slipper clutch is not just loose...
    Indianapolis
    14,321
    You need to take it apart. Sometimes the wheel hex will get round. That will also cause you to only have a front wheel drive truck.
