    Apr 2019
    3
    Traxxas 2 amp NiMH charger. In need of help.
    I have the 2amp NiMH charger (#2977). Today I tried to charge my 7.2v 1800 mAh battery that I only use for my easy start. Everytime I plug it into my car I get a solid red light, plug the battery in and it stays solid read for about a minute. Then it blinks red, I've checked and changed the fuse and it's still the same. Is my battery pack fried? I've only had it for a summer and charged the battery maybe 8 times. It sat all winter long but inside my house. What am I missing guys/gals.
    13,496
    https://traxxas.com/Troubleshooting-DC-Chargers
    https://traxxas.com/sites/default/fi...ctions_WEB.pdf
    Do you have a multi-meter that you can determine what the battery voltage is?
    Apr 2019
    3
    Yeah I can, are you saying to check the voltage coming from the charger?
    Jan 2019
    94
    How many red blinks per set of red blinks?
    While it was not my post above I would have you check the battery pack voltage.
    Apr 2019
    3
    It stays red when given power, then after a minute or so it starts blinking one blink per set. It's like it's not even noticing my battery. Also if the battery is dead will the volt meter still be able to read it?
    Also thanks for the help!
    Jan 2019
    94
    If the battery is so dead that the volt meter can't read it, it is unlikely that the charger is going to want to charge it.
    However, your one blink error code is actually a power source error, not a battery error.
    My advice is to call TRX.
