Results 1 to 8 of 8
    Apr 2019
    11
    looking to upgrade to brushless
    i've seen a lot of reference to Mamba and Toro, but has anyone had experience with the Hobbywing set up? my friend at work said he loves it. just curious what you guys might think.
    also when upgrading to a brushless motor, do i HAVE to change the ESC with it or can i just swap the motor itself? i'm just trying to get more run time out of these things for the kids (6 and 7) through a LiPo upgrade. not concerned with more power whatsoever
    also, if there's a way to keep things waterproof that would be amazing! i don't want to seal something off incorrectly and cause some sort of heat issue with the truck
    thanks!
    Mar 2019
    BC, Canada
    30
    I didn't see what forum I was in. I'm an idiot.
    Apr 2019
    11
    that bad, huh? maybe i'll just get the Toro then.
    Apr 2019
    7
    posted without quoting, deleted.
    Apr 2019
    7
    Quote Originally Posted by les4metal View Post
    thanks!
    I've got the Hobbywing EZRun 2030 5200kv brushless motor and 18a ESC with stock 11t pinions: these seem to be the perfect speed for my son at this time, they're quick, controllably fast and definitely power efficient(run times increased with the stock NIMH batteries) very enjoyable driving experience with this setup. I installed a heatsink with thermal paste on the motor due to some running we do in deeper grass, they're cool on smooth surfaces but will overheat in extended grass running.
    The hobbywing 2030 motor doesn't fit perfectly into the mount, it requires some dremel usage and tracking down some m2.5 screws and cutting them to a proper length to mount it up, but after that they've been great.
    I also use Tenergy 2S 2200 Mah Lipo's (item# 34117) (search on amazon) and dang they fit perfectly in the tray with the factory hold down provide crazy run times and punchier power delivery.
    May 2015
    The Netherlands
    12
    Hi!
    In the four years I am racing the Teton I have roasted several stock motors. They were cheap (AliExpress) to replace so I never considered upgrading to brushless. Last week I finally roasted the stock ESC. Now I am upgrading to brushless. Watched many videos on YouTube, read countless reviews. I concluded the HobbyWing offers good value for money, so I decided to go with the Hobbywing Ezrun Combo A1 18A 7800kV.
    When upgrading to brushless you also need to change the ESC.
    The brushless motor has 3 threads to connect. A brushed motor only 2.
    I also expect that I will have to replace the stock differentials. They are made of plastic. Plastic and brushless do not seem to be a good combination. I will probably fry the stock diffs in no time. We'll see what happens.
    thanks!
    Apr 2019
    11
    i just posted this in my other thread but i think this one is where it should have gone so i'm gonna paste it here too:
    one quick question hopefully someone can answer.....i ordered the pinion gears that would give me a 3.17:1 pinion/spur gear ratio and the stock ratio is about 6.77:1....due to it being an electric motor, i imagine the overall speed and power will be unaffected, just the temp the motor runs at will be lower....am i correct in my thinking or did i just get a set up to go 60 mph and have zero torque? haha i heard that too much gear will heat up the motor and cause other issues
    thanks everyone!
    Aug 2019
    37
    It will most definitely affect your power curve. Dropping down to a 3.17 ration will give you much higher top speed / less torque. My guess is that your motor would also get hot at that low of a ratio.
