Results 1 to 10 of 10
Thread: max 5 combo
    Apr 2019
    max 5 combo
    Anyone try this setup on a stock 6s? If so what mods did you do.
    Specifications:
    Motor:
    Model: 56113-800KV
    Pole: 4
    KV (No-load): 800KV
    Resistance: 0.00049 Ω
    Current (No-load): 3.2 A
    Max. Output Power: 5800 W
    Current at the point of M.O.P: 200 A
    Motor Diameter: 56mm
    Motor Length: 113mm
    Shaft Diameter: 8.0mm
    Shaft Length: 31.0mm
    LiPo Cells: 3-8
    Weight: 1210g (42.68oz)
    Application: 1/5th RC Vehicles, Truck/Dragster
    ESC:
    Continuous Current: 200A
    Peak Current: 1,300A
    Motor Type: Sensored / Sensorless Brushless Motor (only in sensorless mode)
    Applications: 1/5th Touring Car, Buggy, Truggy and Truck
    Motor Limit: With 8S LiPo/24-Cell NiMH: KV ≤1000 (58110 size motor)
    LiPo/NiMH Cells: 9-24S NiMH, 3-8S LiPo
    BEC Output: 6V/7.2V Switchable, Continuous Current of 6A (Switch-mode BEC)
    Cooling Fan: Powered by the stable BEC voltage of 6V/7.2V
    Connectors: Input End: None, Output End: Female 6.5mm Gold Connectors (pre-soldered onto the PCB of the speed controller)
    Size (LxWxH): 93.35x58.12x47.81mm
    Weight: 342g
    Programming Port: FAN /PRG Port
    Oct 2016
    4,199
    Use the search function. Thereís quite literally a thread dedicated to a setup almost identical to your question.
    May 2009
    43
    Use the search function. There’s quite literally a thread dedicated to a setup almost identical to your question.
    Didn’t see a sticky. Could you share the link to the thread you are referring to thanks in advance
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    Mar 2016
    1,151
    As of now I have the same setup except my motor is 960kv on 8s
    And it’s a monster..
    But I’m still waiting on my leopard 58113 V2 870kv to arrive.
    "AVENGED SEVENFOLD "
    May 2009
    43
    Looks like ill have to upgrade the rear bulkhead, rear diff and pinions to 8s.
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    Oct 2016
    4,199
    Ah. I get it now. You have a V1 X-Maxx, not an V2 running 6S. As Iím writing I canít copy links and things but youíre gonna need, newer shocks, axles, Center shaft, Cush drive or slipper eliminator, new hardened spur and pinion, diffs(bulkheads), wheels and tires, and someone will chime in with more.
    Jun 2017
    Ohio
    1,325
    Motor mount
    May 2009
    43
    Ah. I get it now. You have a V1 X-Maxx, not an V2 running 6S. As I’m writing I can’t copy links and things but you’re gonna need, newer shocks, axles, Center shaft, Cush drive or slipper eliminator, new hardened spur and pinion, diffs(bulkheads), wheels and tires, and someone will chime in with more.
    lemme know what you recommend for center shaft. For now im just upgrading what traxxas was listing in there 8S upgrade kit.
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    Oct 2016
    4,199
    Quote Originally Posted by IamRevoMaster View Post
    Integy is the only one who makes one. Itís billet aluminum, Iím not an Integy fan, but the shaft has held up well. The stock ones will bend after a while. Itís not a necessity, just keep an eye on the stock piece.
    May 2009
    43
    Cool. Thx bud
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
