Results 1 to 15 of 15
Thread: Brass Weights
    Feb 2017
    UK
    442
    Brass Weights
    Anyone using brass portal covers/weights??
    If so, which ones??
    Im current looking at either Yeah Racing or SamixRC.
    Thoughts?
    N. Idaho... Da Sticks!
    7,445
    I went with GPM Racing portal covers, the fit and finish are great.
    Post #12 on my TRX4 thread...
    https://forums.traxxas.com/showthrea...atScott-s-TRX4
    Aug 2018
    Oshawa, Canada
    109
    Did you install all four or do you find that only front weight is needed?
    RC Competitor T-N-T's Avatar
    Feb 2019
    90
    Quote Originally Posted by Trailwalker View Post
    If you follow his link you'll see 4 portal weights.
    Slash Ultimate, Slash 2wd, TRX-4 Defender & Sport
    Aug 2018
    Oshawa, Canada
    109
    Quote Originally Posted by T-N-T View Post
    Right, that's why I'm asking. Does installing all four help more than just adding front weights?
    Feb 2019
    90
    Using 4 definitely helps out for my terrain. I like about 300 grams of brass in the front and about 200 grams in the rear.
    7,445
    Absolutely! The added weight down low only helps its stability, and move other mass to get a 60/40 balance.
    Aug 2018
    Oshawa, Canada
    109
    Awesome! Honestly, getting 60/40 on a Trx-4 is really difficult without some major mods/item relocation/body swap.
    Feb 2019
    90
    Down low and wide out by the wheels is the way to go, moving or removing a few other items really helped.
    It's really not that hard to get a 60/40 weight ratio. You can get there with just brass alone. It's only money.
    7,445
    60/40 is the typical starting point for setting up your scaler (70/30 for a crawler), but honestly, once you get the weight down low, it becomes less critical to performance.
    Yup, that is why my OT money is my toy money...
    Jul 2013
    Northern Norway
    846
    Quote Originally Posted by IftiBashir View Post
    If so, which ones??
    Thoughts?
    I went with Samix to avoid the shiny brass color. The machining and fitment is second to none on the Samix parts.
    Weighing down all four corners is beneficial when sidehilling.
    Feb 2019
    I have installed a lot of brass upgrades, all from "AliTuning". Portals, knuckels, shock-mounts, bumper/servo mount, links....
    Just a few examples....
    Feb 2017
    UK
    442
    I don't want to go any further then brass portals to be honest. I feel adding too much weight low down could also be detrimental to performance, ie, the truck could tip easier when sidehilling due to the added weight.....?
    https://www.youtube.com/user/iftibashir
    Feb 2017
    UK
    442
    What did you use to widen out the wheelbase?
    Feb 2017
    UK
    442
    Samix RC full set of brass portal covers and knuckles on their way
