Results 1 to 7 of 7
    Apr 2018
    42
    2.0 toe adjustment
    Any body know the measurement for what the toe adjustment is supposed to be on the 2.0? This is all i can find
    Thank you!
    Sent from my SM-G960U using Tapatalk
    kansas
    8,683
    what are you trying to do?
    Apr 2018
    42
    Adjust the toe to factory spec
    May 2018
    Canada
    20
    Says right on the manual you linked, highlighted in yellow: “Toe base factory settings. Front: 0 degrees. Rear: 1-degree toe-in each side.”
    Dec 2014
    Adirondacks
    266
    Quote Originally Posted by Ultrae05 View Post
    There is no set mm toe-link length measurement as each vehicle will be different. I just set it up by eye, both pointing straight ahead.
    kansas
    8,683
    https://forums.traxxas.com/showthrea...=1#post5361495
    there is a lot in here just have to find it. the fronts as stated just adjust as needed
    https://forums.traxxas.com/showthrea...=1#post5570078
    Apr 2018
    42
    I am starting from scratch, my truck is adjusted so incorrectly its all over the place while running. I am looking for a specification like my losis provide in manual. Adjust as needed doesn't give me a starting point. I will call traxxas and ask for measurements
