Results 1 to 19 of 19
    Sep 2017
    41
    4X4 feels almost like RWD
    Hi all!
    A friend of mine (really seriously not ME haha) has some weird problem with his Slash 4x4. It feels almost like RWD. Like the 4X4 isnt workin properly. He’s cleaned and re-filled the diffs (30k front and grease on rear), but doesn’t seem to help.
    100k center diff. The slipper made it a tad better but not a whole lot.
    The looser the surface the more of a RWD effect.
    I have same truck with all same setup and parts and I can accelerate at full throttle out of a corner and he has to be really gentle on the throttle. Otherwise he’ll spinn.
    Also makes the rear loose under breaking too.
    Is a lot ”looser” than mine even when you just let go of the throttle.
    Any idea what should we do about it?
    RC Champion RazorRC22's Avatar
    Sep 2015
    2,149
    Turn each wheel by hand, does the diff feel the same as yours does?
    Take off the shocks, do the arms move freely up and down when the shocks are removed?
    Check each shock by itself, can you operate them to full extension/compression or are they hydro-locking?
    youtube.com/c/RazorRCvideos
    Apr 2019
    71
    I have had this happen on a few occasions,
    1.) Stock center driveshaft hub was broken
    2.) Tekno center driveshaft grub screw was loose
    3.) Front axle was broken
    4.) Front wheel and hex were stripped
    5.) The inside of a front hex was torn apart by the pin. Looked fine and spun by hand like normal.
    Slash 4x4
    Rustler VXL
    13,215
    Quote Originally Posted by Trojan366 View Post
    5.) The inside of the hex was torn apart by the pin. Looked fine and spun by hand like normal.
    +1 .
    Dec 2014
    Adirondacks
    136
    Do you or your freind have TSM? If your friend does is it set the same as yours? TSM could also cause control differences. I noticed turning TSM up helped greatly with control of a vehicle.
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,589
    I'm all in on front grub screw or shaft. He's probably not getting power to the front axle, hence it feels like a RWD.
    Jun 2014
    Southern California
    7,393
    Agreed.
    Check the grub screw on your front drive hub (the part the center drive shaft couples with).
    Good luck!
    Feb 2010
    Indianapolis?
    14,045
    I've had a broken hex pin that caused the same problem. A blown differential will also cause the aforementioned problem.
    Sep 2017
    41
    Thanks for the replies guys! We’ll check those points out!
    As a note; It does pull with all 4 tires for example if you accelerate from a stand still on gravel.
    Sep 2015
    2,149
    "Thanks for the replies guys! We’ll check those points out!
    As a note; It does pull with all 4 tires for example if you accelerate from a stand still on gravel."
    LOL
    Sep 2017
    41
    Quote Originally Posted by RazorRC22 View Post
    LOL
    What?
    Apr 2019
    71
    When the inside of my front hex was stripped the truck acted like that. The was enough friction to spin the wheel on loose material but under hard acceleration or braking it would slip.
    Slash 4x4
    Rustler VXL
    Sep 2015
    2,149
    Quote Originally Posted by Kummeli View Post
    What?
    Sorry, I just think it's funny that you report a symptom, and people tell you what your problem is. But there are so many possible causes that it's impossible to just jump straight to an answer.
    IMO, first step is to ask more questions so that you can isolate where the problem is coming from. I don't have the answer, I just have more questions. But eventually you'll get to your answer as you work through it.
    Sep 2017
    41
    Sure I understand all that. I just wanted to make clear that all the wheels do pull since some of the answers felt like they had to do with the front not working at all.
    Sep 2017
    41
    UPDATE:
    The hexes are fine. As are the center drive shaft and it’s hubs.
    The diffs feel same as mine (we pulled then apart). However, if you push the axles inwards and turn; my friends rear diff isnt as smooth as mine. You get more of the ”teeth”.
    Also, on front diff there’s more play in the ”hub” that connects the diff to the center driveshaft. And if you turn the hub in some; you can barely turn the diff then. We did put a shimming plate between the hub and the bearing and that took the grinding away.
    So maybe the front diff is really worn?
    Jun 2014
    Southern California
    7,393
    Time to open it up and inspect.
    Feb 2010
    Indianapolis?
    14,045
    I understand that tearing into these trucks can seem a little daunting. Just make sure you do it in a space where you can easily keep track of all of the parts you disassemble. Go slow and enjoy learning about your truck
    Apr 2019
    16
    Taking a trick from the on-road world, you might try running lighter fluid in the front than the rear. Running a harder fluid in the rear is essentially like locking the diff, which is pretty much how you might get a drift car to drift.
    Jun 2014
    Southern California
    7,393
    Haha! At first I thought you were recommending he run lighter fluid in his front diff.
    Not lighter weight silicone diff oil... actual lighter fluid!
    Kaboom!
