Results 1 to 16 of 16
    Mar 2019
    7
    Wheels turn, no torque ... help pls
    Hi. Welcome everybody, it's probably common and silly issue so please advice... Car can turn wheels but no torque ...receiver and controller solid green light. I can't attach video but controller and receiver has solid green light and when pressed on controller to move receiver green light start flashing. No torque. Please dear professionals advice is that mechanical issue or fault in controller receiver connection.
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    398
    Welcome to the Forums!
    Are you saying that the motor turns the wheels, but has no torque? Or that you can spin the wheels but the motor doesn't turn? I am guessing you either have a loose slipper, or something isn't plugged in right.
    I like free stuff!
    Mar 2019
    7
    Hi yes that's correct, wheels turns but no drive ... I don't know what's can't be plugged correctly, didn't change any set up and was running correctly till now ...
    Feb 2019
    Yakima Washington
    398
    I don't know, but you can call Traxxas and ask them. They might replace or fix your electronics. Hopefully someone with more experience then I will help you.
    I like free stuff!
    Mar 2019
    7
    Thanks for your help!
    Apr 2018
    848
    Check the connections to the motors and make sure they are tight. If all else fails, like said above, call Traxxas and have them troubleshoot with you ans worst case you may have to send your electronics in and let them troubleshoot them. If the vehicle is still under warranty you may not have to pay for things. Good luck and let us know what it was.
    RC Champion akrimmel's Avatar
    SAINT CHARLES, MO
    2,567
    Same thing just happened to me Alexrugby, your transmission is caught between gears, check your servo and try manually shifting it manually.
    U.D.R. IN FULL MOD MODE
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,567
    Also I just upgraded 2 the MMX w/2200kv, all Castle Creation of course
    MMX SUMMIT 2200KV!
    SAINT CHARLES, MO
    2,567
    BTW I adjusted the slipper to be ttiigghhtt, all was good.
    MMX SUMMIT 2200KV!
    Mar 2019
    7
    Thanks for your help guys, local traxxas dealer identified electric motor faulty but this conclusion comes after just looking not even touching this unit ... so he is professional or looking for a easy way... I will go with your advices first! Thanks
    Mar 2019
    7
    Hi guys ... so I finally received new motor and replaced successfully (???) but ... now wheels spinning super fast but not turning ... before my "maintenance " Wheels was turning perfectly but there was no torque ...now driving forward but wheels don't turn ( only slowly when lifted from the ground ) ???? What did I set up wrong ???
    Jan 2019
    184
    You mean no steering right? You may have a burnt servo.
    Mar 2019
    7
    What could cause this? Before changing the motor steering was perfect... is that wrong motor replacement procedure?
    Dec 2014
    Adirondacks
    272
    I'm a bit confused on the issues you have. Do you have a problem with steering? Did you touch any of the ESC connections? Try unplugging the drive motor connections (stock titan motor the 2 red wires and 2 black wires on the motor) and see if steering is better. If you touched any of the ESC connections the steering servos could be plugged in the esc slots wrong or a bad servo.
    Dec 2014
    Adirondacks
    272
    Also check your pillow ball caps. If you tightened them up to much it would cause weak or no steering.
    I don't know what you did or serviced for "... before my "maintenance "."
    Mar 2019
    7
    Grizzly thanks for your advices. Apologies for confusing you guys, I had steering perfect but no torque so replaced motor and after this step (as I called maintenance etc...) I have perfect torque but lost steering... it's turns a bit when is lifted off the ground but absolutely no reaction when is connecting the ground. When ESC (2red and 2black)unplugged is still no steering ... as steering was perfect before changing motor that's must means I did something wrong during changing motor (???)
