    Apr 2019
    15
    What is the this missing part called on my Slash 4x4 Platinum
    I just noticed my front shocks stay down after i put weight on the car, i think this is the problem.
    Had a little "get together" with a tree the other day, i bet that's when i happend. :-)
    I just wonder, what is the name missing part(s)?
    I'm looking at the exploaded view;
    https://traxxas.com/explodedviews/68...h-4X4-Platinum
    Do i only need the #2668 part?
    Jan 2019
    154
    It is called a spring cup. Don't know the part number. You might want to check your camber link, because they are supposed to connect to the hub not the A-arm.
    Aug 2015
    420
    Those look like GTR shocks, there should be a shock kit with spare parts you could buy or just order individual parts. A tip for losing those cups, if the spring doesn't keep a slight amount of tension on full shock extension the cups have a tendency to fall off. I don't see a problem with the camber rod but your sway bar link is missing a screw on the arm.
    13,307
    Spring retainer. It's a bummer that they don't get sold separately.
    https://traxxas.com/products/parts/7468
    https://traxxas.com/products/parts/7468X
    Apr 2019
    15
    Ah i see, thanks ALOT. You guys rock. I will pick these up ASAP.
    I'm seeing the missing screw too, and it's the same on the other side. But it seems solid enough. Wierd.
    Indianapolis?
    14,094
    Quote Originally Posted by dgechrgr469 View Post
    What screw are you referring to? I'm not seeing anything missing?
    RC Qualifier NOFTCHX's Avatar
    May 2015
    New Hampshire, U.S.A.
    798
    The newer sway bar links don't use the screws. They come with a pivot ball on the end that screws into the a-arms with a 2mm or 2.5mm hex driver.
    "Theres not bad people, just bad choices."
    Aug 2015
    420
    Didn't know that, it looked like a hollow ball in the picture.
