Results 1 to 8 of 8
    May 2019
    7
    GTR Shocks on 2wd Slash?
    How do you put GTR Shocks on a 2wd Slash with lcg chassis? What arms do i need?
    Sent from my SM-G975U using Tapatalk
    13,328
    Remove existing and replace with GTR.
    May 2019
    7
    Its not that easy bud... the bottom of the gtr shocks are bigger than stock slash shocks. Not allowing it to fit into the a arm slots. This happens only for the fronts.
    Aug 2015
    420
    Quote Originally Posted by sung.sung.12 View Post
    Pop the hollow ball from the old shocks and put them in the new GTRs. If you measure the GTR ball you'll see they're wider. Even with the narrower ball in place you sometimes need to spread the arm to get the end in.
    Sent from my VS996 using Tapatalk
    May 2019
    7
    Ok thx, but how do i pop the ball out I've tried with no success.
    Aug 2015
    420
    Before i bought a shock pliers i used a regular pair of pliers. Put one jaw on plastic rod end away from the ball and push the ball through with the other pliers jaw. I also used the shaft of a hex driver to pry them out using the hole in the ball.
    13,328
    Then your experience is different than mine.
    May 2019
    7
    Double G what front arms are you using... im using rpm are you using stock?
