Results 1 to 9 of 9
    Oct 2018
    Southern CA
    70
    End to wheelies?
    My slash 2wd with the castle sidewinder system wheelies, catches the air, and as a result flips over. Any solutions to stopping wheelies? Thanks in advance!
    13,529
    Left pointer finger control.
    RC Champion Mr Wolf's Avatar
    Malmesbury, UK
    1,695
    Since you have a Castle ESC, IMO the best solution is to hook up your ESC to a PC and limit the motor's torque via the setting.
    It limits torque by limiting the amp draw so unless you go for a very low setting (say <6.0) it won't impact top speed at all. Somewhere between 6.0 and 7.0 used to work really well at taming my 3800 motor when I used on the track. Level 10.0 is maximum (i.e. unlimited). I found any setting above 8.0 and I couldn't notice any difference at all.
    Other options - loosen your slipper a tiny bit or fit a wheelie bar.
    Pretty please, with sugar on top, clean the RC car
    Dec 2017
    North Texas
    626
    Lead weights in the front bumper.
    Try to position the battery as far forward as possible.
    Rake the rear suspension higher.
    Learn throttle control.
    Mar 2004
    N. Idaho... Da Sticks!
    7,609
    Are you talking about wheelies when you are first accelerating, or the front end lifting at high speed?
    Dec 2016
    Burleson, Texas
    238
    Quote Originally Posted by Greatscott View Post
    YES. Mine was doing both until I learned how to balance throttle - even at speed just a little off throttle will help a lot.
    Scott
    Slash 2wd
    Slash Ultimate 4wd
    Stampede 4wd
    Mar 2019
    As an aside: My stock VXL has never even thot about a wheelie. Would you say the stock ESC is that limiting and/or a different spec. ESC would give that much more? [ not that I need that much more speed ... I race an indoor, really, really, really short course using a 14T pinion and 90T spur. ]
    Jan 2019
    184
    CountOmar, you could loosen your slipper clutch a little bit, I run mine in 3/4 from Full tight, or wheelie bar would probably be the true solution here. The programming Mechanic mentioned would work as well.
    Oct 2019
    19
    Probably time to install a low-riding, long wheely bar.
