    May 2019
    11
    Rustler TSM receiver 6533 problem
    So I upgraded my Rustler VXL and installed a new Traxxas TSM receiver 6533.
    Steering servo in Ch1, the ESC in Ch2.
    Before the upgrade, the car ran perfectly with the old 2218X receiver and 2238 Radio.
    After installation I binded my new 6528B Radio, which replaced the old 2238 Radio.
    Now, the car will run great for a few minutes and all of a sudden will stop accelerating like you let go of the trigger. Pull the trigger again after a second or two, the car will accelerate again then usually stops again. This scenario repeats itself over and over until I get fed up and turn everything off.
    Note that my 2WD Slash VXL runs fine with the same 6528B Radio and batteries I use in the Rustler.
    Any ideas as to the problem? I’m thinking the new TSM receiver 6533 is defective….
    Thanks!
    Nov 2017
    Upper Mid-west, USA
    168
    I would love to help but I'm new too.
    Apr 2018
    Make sure you recalibrate the receiver AND the ESC. Made that mistake before myself.
    RC Qualifier Rich2's Avatar
    Feb 2014
    Western New York
    628
    Quote Originally Posted by area54 View Post
    Thanks!
    If that receiver didn't come in your truck new:
    "A Traxxas TQi transmitter with the Traxxas Link Wireless Module (part
    #6511) installed is required to control the receiver within the Traxxas Link
    App (see Related Parts List). A TQi transmitter equipped with the multifunction
    knob is required to adjust the TSM assistance. The Traxxas Link Wireless Module
    is also required in order to load the proper software for your specific vehicle
    model into the receiver."
    Feb 2014
    Western New York
    628
    Thanks!
    Quote Originally Posted by Rich2 View Post
    BTW, if you don't have a bluetooth transmitter you may find a friend with one
    or even your local hobby store to do it for you.
    May 2019
    11
    Quote Originally Posted by cyclist View Post
    Thank you for the reply.
    I did reset the transmitter to its factory default settings and the ESC but it did not fix the problem.
    May 2019
    11
    I guess I will look into getting the link module. I'm sure my local hobby shop may also do that for me for a fee...
    May 2019
    11
    Update: Bought a link module.
    Updated the firmware on the new TSM receiver, along with a second one I acquired, and the problem still exists with either one installed.....
    Jun 2019
    Albuquerque, NM, USA
    3
    Their link is needed for a software update, but all else can be done manually. When it runs great for a few minutes, does everything work correctly? Forward, brake, and reverse? If so, your setup should be correct. Now, try it again, while controlling the distance. See if it only fails at some distance. What you described matches a broken antenna at either end.
