    Apr 2019
    10
    Power HD servo problems
    I recently installed PowerHD23kg waterproof high torque servo and when I steer the light on my receiver turns red and the servo rested to neutral. Also if I try to steer while holding the throttle it does the same thing.
    13,321
    What batteries are you using?
    Apr 2019
    10
    AA’s I have a tmaxx 3.3 but my previous servo worked perfectly fine. Is there a way to reset the receiver?
    13,321
    It is not the receiver but the battery. Four AA batteries don't last that long and four rechargeable are not recommended due to their voltage rating. Best to get a rechargeable receiver pack and consider a glitch buster to help with any heavy draw.
    Apr 2019
    10
    Do you have a recommended battery?
    13,321
    The Traxxas receiver pack: https://traxxas.com/products/parts/b...mp-23A-1200mAh is good. I run equivalent sized 1600mah Reedy packs.
    Oct 2005
    South Florida
    19,477
    Remove the servo horn from the servo, verify your linkages are turning them wheels without any binding.
    +1 5 cell rechargeable packs are the way to go, 1400 mah rating minimum... IF you still experience the problem maybe the servo has an issue.
    Also, I forgot another thing, if the end points are set further than what the steering linkage allows your servo can be fighting it and eating up battery power as well. Combine alll the above and you should be covered.
    All Lives Matter
