    Nov 2015
    598
    Widening the X Maxx
    Hello, I run Badlands MX43's on the Proline wheels, but would like to increase the width of my X-Maxx, does anyone know of any axle extenders? I've saw these but dont know if theyre any wider?
    https://www.ebay.co.uk/itm/1-5-2PCS-...r=413549795923
    Thanks
    Eastern Shore, Maryland
    3,890
    I personally don't know of anything.
    Aug 2017
    251
    I donít know of any kit to make the x maxx why wider. Also those just replace the plastic ones one the truck there not any wider.
    Nov 2015
    598
    Quote Originally Posted by Nightflier x4.6 View Post
    I don’t know of any kit to make the x maxx why wider. Also those just replace the plastic ones one the truck there not any wider.
    The ones in the link are 13mm and stock are 10mm so technically they would increase width by 6mm total, but not sure if the wheel nuts will hold on enough?
    Aug 2017
    251
    Yes that might be a problem.
    Jun 2017
    Ohio
    1,197
    Measure how much stub axle you have on the outside of the wheel nut, if it's any more than 3 full mm you should be good to go. If you don't have a caliper I can measure it for you in a bit. I looked this morning for extensions, I know a friend of a friend has a set on one of his speed run xmaxx. I'll see if I can get ahold of him.
    Jun 2017
    Ohio
    1,197
    I took a look at mine, there is only 1.7mm of stub axle left on the outside of the wheel nut, only 2 threads for about 1mm of it, so probably not going to work with the badlands.
    Nov 2015
    598
    Wasnt worth the hassle for 3mm anyway, but thank you for checking
