    Jun 2016
    12
    lower cg revo 3.3 nitro truck
    Hi guys i have revo 3.3 #5309
    most driving is on road
    and few times my revo rolls in corner
    it is possible to lower it (closer to the ground?)
    what parts i need to take to make it closer to the ground
    thanks?
    13,500
    Put some limiters (fuel tubing) on the shock shaft inside the shocks; put the pushrod in the outside holes in the lower suspension arm; add sway bars and read up on the Roll Center section of your manual (which is around the suspension tuning).
    Jun 2016
    12
    i put push rod on last hole closer to the tire but its still to high
    does exist shorter push rods?
    when i remove them and move itcloser to the tyre revo goes down but i dont have place to attach it
    but if pushrod are shorter it will be fine i hope
    Deep Space
    421
    Not sure about shorter push rods. The sway bar kit does add a lot more stability when running it on hard surfaces.
    You can't take the sky from me.
    1,835
    Yes the optinal long travel rods are shorter than the rods ues with the P1 and P2 rockers. Also as double G mentioned some flue tubing on the shock shaft inside of the shock body will help lower it. If all you are doing is road running put the heavier springs on it also this should help with body roll along with sway bars.
    Cads, Insane RC, PWC,and BOAT CORNUCOPIA
    Jun 2016
    12
    thanks on help guys
    Jun 2016
    12
    Today i put progressive 3 rocker and its now like some truggy very close to the ground but i need stiffer spring an 50-60 wt oil
    Maybe longer push rod
    Does any body try it similar?
    Sent from my FIG-LX1 using Tapatalk
