Results 1 to 13 of 13
    May 2019
    7
    Brushless motor install from donor car
    Hi everyone, I currently have a Helion Select Four 10SC and parts are hard to find since they went out of business. My servo recently failed and it could use some new tires so I am thinking about purchasing a base Slash and swapping the brushless motor and ESC from my Helion and I'll be able to continue using my 2s Lipo battery and charger.
    So my question is would there be any issues using the following motor and ESC in the Slash? Any other upgrades to the Slash be required? I am not necessarily looking for top speed, I will be running it around my backyard and will be building a dirt track.
    Reaktor 60-4T brushless power system
    4-Pole Sensorless Radient Reaktor4T 3500kV Brushless motor
    All Weather ESC the 60A all weather Electronic Speed Controller (ESC)
    Thanks for any help
    RC Racer hammie4c's Avatar
    Jun 2016
    404 not found
    161
    There should be no issues with installing that motor/esc combo. Install it and enjoy your new slash.
    May 2019
    7
    Would I need to upgrade the driveshaft or change the gears?
    Jun 2016
    404 not found
    161
    I've run a castle 4600kv motor in my rustler for 2 years and have yet to break any driveshafts or transmission gears. I would start with a 20 tooth pinion gear and an 86 tooth spur gear.
    Jul 2017
    221
    I had a heliom dominus 10tr before and used that motor system in a slash before. It was fast enough for me until I got a better system
    May 2019
    7
    Thanks for the replies.
    Would a Slash VXL be faster? It would be nice to have TSM and I am thinking about doing the upgrade for $68 to the base Slash.
    Jul 2017
    221
    Quote Originally Posted by quiksilver81 View Post
    The vxl system will be faster I'm pretty sure. If I remember correctly the helion system can only take 2s lipo. Vxl can take 3s
    May 2019
    7
    Quote Originally Posted by Mrjelly007 View Post
    It can do 3s
    May 2019
    7
    Just picked up the basic Slash with the upgraded remote and TSM. Also went ahead and bought the LCG kit.
    Jul 2017
    221
    Nice! Toss in the motor and esc and see how it is. I bet it will be pretty good
    May 2019
    7
    So I ran it out back yesterday and it’s definitely slower than my old Helion in the dirt (4WD vs 2WD) and our Arrma Senton. On pavement though it keeps up with the Senton just fine. I’ll be installing the LCG kit today or tomorrow along with some 19/86 gears that I ordered which should help the acceleration and I’ll have to start learning suspension tweaks to keep it fast in the dirt.
    May 2019
    7
    So I installed the LCG kit and put in the optional 23/86 (my understanding stock VXL) gears in the car today and I really like how it drives now. I then put in my 3s battery I just got and the front starts lifting up and flipped on me once.
    What are safe temps I should be seeing on the motor, ESC and transmission? After a few hot runs back and forth down the road for about 10 mins I saw a peak of 145 around the motor transmission area.
    Jul 2017
    221
    Check the temp on the motor can itself. People argue about what temperature is safe but as long as it's not near 200f it should be ok. Try and keep it under 175f. The esc I'm not sure.
