Page 3 of 3 FirstFirst 123
Results 81 to 108 of 108
  1. #81
    Jan 2019
    SF Bay Area
    807
    Quote Originally Posted by Icehawk View Post
    After some trials & tribulations my Rusty is working - when I tried to connect the BEC I got a fast flashing green light... turns out there is a bad channel on the receiver as I was able to get everything working after trying a few different channels.[/img]
    Anyone know what rod end I need to repair a Hot Racing swaybar? I've gotten zero response from email so far.
    Just curious, but what channel(s) did you initially try? Assuming you're using the stock Rx, not all of the ports on the Rx are "channels". For the BEC, the most likely ports...probably, the only correct ports...to use are the Ch 3, or Ch 4, ports (ie. the two immediately above the two used by the ESC & servo). The others should be avoided.
    Starting with the port below the two used by the ESC & servo (ie. the second Channel 1 port), that's for use in vehicles utilizing a dual-servo setup (ie. the E-Revo), so that's NOT one to plug the BEC into. The top two, in their own 'section' are for telemetry, so those are also NOT to be used for the BEC. In the main section, the top one (just below the two previously-mentioned) is labeled "Batt/Ch 5). Honestly, I'm uncertain as to whether, or not, you can use that for the BEC. I haven't figured that one out...but, as I'm replacing my Traxxas units with Futaba, I don't have to think about it anymore.
  2. #82
    Jan 2019
    SF Bay Area
    807
    Been almost 3wks since anyone's posted in here...and I'm the last person to post...so, here's my latest "update", as minimal as it is. I only had 15-20min to work on my Rustler conversion project today, so did the shortest, & simplest, thing needing to be done - drilling out the hub extensions. It's (somewhat) quick, but not as simple as I thought it would be.
    I purchased Hot Racing 15mm aluminum hub extensions, designed for the Axial crawlers. The problem was, while the part of the axle closest to the vehicle is 5mm, that's only for the first 6-8mm of the axle stub...after that, it drops down to slightly less than 4mm. So, in order to get the hub extensions to work on the Rusty, I had to drill them out to 5mm.
    The first problem, which I resolved several days ago, was finding metric drill bits. Found several on Amazon & eBay, but, considering the super-cheap prices, I doubted they'd last beyond this project...IF, that is, they later even that long. Home Depot carries some, but being "industrial machinery grade", a 6-piece set was over $100. Thankfully, Granger had a few beans of decent-enough quality sets, made using high-speed steel, in the $30-60 range...got myself a 9-piece set for less than $45.
    Next problem...a directly work the 5mm bit was a "bad idea" - it bound-up almost immediately. So, changing tactics, I first drilled out all 4 using the 4mm bit, them repeated the prices using the 4.5mm bit, and, finally, repeated the process using the 5mm bit. In the end, I was 'rewarded' with four 15mm hub extensions that perfectly fit the Rusty's 5mm axle stubs. Tomorrow, whole my car is being worked on, I'm hoping to finish this project, not counting the electronics, or painting of the body.
    Sent from my SM-N975U using Tapatalk
  3. #83
    Jul 2019
    Greeley, CO
    538
    Today I procrastinated putting the metal shock caps on my blown out shocks...but I did buy ANOTHER Rustler though....this one is going to be a custom project and not a runner.
    I have some ideas I'm planning on trying out with it requiring some fabrication to transform it into something unique. It's a double-secret project!
  4. #84
    Jan 2019
    SF Bay Area
    807
    Quote Originally Posted by USMC1984 View Post
    In other words, you don't have a clue, yet? Lol
  5. #85
    Jul 2019
    Greeley, CO
    538
    Quote Originally Posted by Panther6834 View Post
    I do have a clue...I'm being completely transparent about that but not with any details yet as I'm not quite sure if it's going to work...AND...Like many of my projects, start/finish dates are highly subjective and quite elusive. In other words...I often start other projects in the middle of current projects and, well, outcomes can become quite sketchy! LOL
    I did go far enough to buy a whole new vehicle for the project though...so that's some type of commitment at least!
    Then again, I did buy stuff for the current three or ninety projects also.
  6. #86
    Jan 2019
    SF Bay Area
    807
    Sounds just like me. Although, I will mention that, for two other projects that are in various stages, instead of purchasing entirely new vehicles, I thought it best to purchase (new) rolling chassis...far less money (approx $100 each), no wasted electronics (since I knew I wouldn't be using any of the Traxxas electronics), and no wasted body (since I wouldn't be using those, either). On one of them, the seller already took care of dying the chassis pan black (I'll do the other, as I already have the RIT dye, which I used on the first Rusty).
  7. #87
    Jul 2019
    Greeley, CO
    538
    Makes sense...I needed pristine parts and will use all stock electronics...buying a whole car was cheaper than buying all new parts separately for me.
  8. #88
    Jan 2019
    SF Bay Area
    807
    Understandable...even in real cars, "the parts cost more than the whole". While I am replacing the electronics in the Rusty I purchased, I am keeping them as "backup" for all three vehicles. If anything happened to any of the electronics on any of the three, at least if still be able to run that vehicle while awaiting a reply for the affected part.
    Getting back to my project, I discovered yesterday that the adjustable-hight body mounts won't work (at least on the Rusty, but I'm holding onto them for the Slash project). Looks like I'm now needing to order the TRA6815R body mounts...another delay.
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
  9. #89
    Jul 2019
    Greeley, CO
    538
    For my non-Rustler scale shelf queens I'm going to be using custom mounts with magnets so there will be no pins showing...then again those bodies will not be run to where they need more than that.
    As for the Rusty...I had to buyA-Arms today! The one time I ran it on 3s I blew out the front shocks and apparently tore one A-Arm off the pin in the front.
    ...just reenforces my Tim Taylor theory...add power and break stuff!
  10. #90
    Jan 2019
    SF Bay Area
    807
    Today, started the "final step" - the body. Got the body prepped, taped-up, & the first color sprayed. Tomorrow, I'll get body mounts installed, the second color sprayed...and, if time permits, maybe even the third color. Colors will be blue, red, yellow, black, silver, and titanium.
  11. #91
    Sep 2019
    7
    Installed GTR Shocks with 50WT Oil and VG Racing Springs on. (Ultra caps kept popping off and oil was getting all over)
    Changed out the A arms to the Green colored A arms. (Mostly because I broke the Front Right Pin hole)
    Put on the Traxxas ESC Fan. (ESC would previously shutdown after 8-9 minutes due to thermal throttling)
    Had the car for about 2 weeks now, went through 10 battery packs of time, made all these changes on 9/15...not today
  12. #92
    Sep 2019
    7
    Today I installed the MIP X-duty CVD's on the front and back, as well as Proline Trencher Belted HP tires front and back.
  13. #93
    Jan 2019
    SF Bay Area
    807
    Today I finished my "conversion" project...well, at least that was the plan. Unfortunately, despite what Colonel John "Hannibal" Smith would always say, a plan doesn't always 'come together'. I trimmed the body, and went to test-fit it...only to discover a problem...which led to another, and then another.
    First problem - the body sits way too high above the chassis, as the JConcepts Suspension Conversion Kit's carbon fiber towers were too tall (the front is the save height as the rear, thus the reason XXL GTR shocks were to be used front & rear. To resolve this, I needed shorter shock towers. Unfortunately, even using the front Slash 4x4 tower at both ends was still too high...I need even shorter towers (I'll save what I ended up using for the sperate thread I'll be creating soon).
    Second problem - even with the shortest towers I was able to find, in using the body mounts, the body still sat too high. I tried installing the body mounts upside-down, so that they curved downward, instead of upward. While this did get the body closer to the chassis, it still wasn't low enough. I solved this problem by some serious modifications to the body mounts (all I'll say here is that some heavy Dremel work, as well as CA & Loctite glues, was involved.
    Third (and, hopefully, final) problem - After solving the shock tower & body mount problems, reaming to holes to mount the body, and discovering that everything is "as good as it's going to get" (the heavily-modified front body mount leaves approx 1mm between the top of the shock tower & body), I finally installed the shocks...only to discover that the chassis sits too high. Because of the switch to shorter shock towers, the XXL shocks have my "converted" Rusty a 'monster truck appearance'. Unfortunately, my LHS only had one pair of the 'Long' in-stock, and they were black (I'm going with blue)...so, I had him order 2 pair of 'Long' (TRA7461) shocks, which should arrive on Wednesday.
    Guess completion of my "conversion" project has been delayed once again. So, in the meantime, I'll start building my TLR 22T 4.0 (2WD competition-grade 1/10 Stadium Truck).
  14. #94
    Sep 2019
    20
    Not much... just heavy bashing.
    I did throw on a set of MX28 Badlands and trimmed the body a bit, and dropped the gearing for heat consideration
    The anti turtle feature does work consistently with the MX28 installed.
  15. #95
    Apr 2019
    Miami, FL
    49
    Got two SMC 2S 5200 batteries to replace my junk Amazon ones. Seems like they have a little more punch but when I was using them I was getting a bit of hitching on hard launchs - not sure what that's about?
    I've given up on the bellcrank I ordered 2 mos ago from China and went ahead and ordered one that's in the US... haven't been using the truck much because the steering is not working well since it looks like the servo saver is essentially blown.
    Weather should finally start cooling off more regularly which definitely means more bashing
  16. #96
    Mar 2018
    25
    So having sold my Sl4sh (still haven't sold my St4mpede) yesterday I picked up a brand new Rustler 4x4 VXL for my 10yo.
    It has, before it's even been run, been upgraded with the Traxxas sway bar set, Proline Powerstrokes front and rear, aluminium hex hubs and flanged nuts, Proline Badlands (SC 3.0/2.2 size) and I've put tape on the bottom of each side of the body, and above where it latches, where it rubs the paint off. I also had to spend some time adjusting the camber, etc, which was all off out of the box.
    Hopefully the weather's good enough it can get a run today.
    From Melbourne, Australia.
  17. #97
    Mar 2018
    25
    Quote Originally Posted by lsear2905 View Post
    The weather was good enough, so 2 runs.
    I have now added a heatsink/fan combo - even on 2S with an ambient temp of 16įC the motor was hot. Fun car, and handles very nicely with the sway bars, Badlands and Powerstrokes.
  18. #98
    Apr 2019
    Miami, FL
    49
    Nice, it is such a fun little truggy isn't it?
    Installed the STRC bellcrank this morning but I'm waiting for it to cool off a bit more before I go for a run outside. Looks like I might need to adjust the toe links a bit but otherwise went together easily. Man those bearings are tiny! I'd love to see the mounting structure stiffened up too, it's all so soft - I know some of that is to prevent damage but my lord.
    Also ordered another set of the stock wheels/tires to replace the worn out originals, I had considered a few other options but in the end I think the OEM setup is pretty decent at $50 for all 4 corners premounted.
  19. #99
    384
    I really like the extra stiffness of the STRC bellcrank. The plastic uprights the bellcrank mounts on are braced to the chassis at the top when all assembled. The top of the cap screws is held by recesses in the chassis.
    I had my stock servo in my stampede 4x4 for years on the plastic bellcrank. It lasted about 4 minutes with the more rigid alloy I do have the STRC cranked down though, but a decent metal gear servo is good insurance.
  20. #100
    Apr 2019
    Miami, FL
    49
    Broke the stock servo with the 2nd battery pack I've got the bellcrank cranked as tight as possible as the servo I have on I am not too concerned about damaging, I have a metal steering horn as well.
    Got the new W&Ts last night and found I'd totally effed up one of the hex/wheels currently on the truck, I managed to get the hex totally jammed into the wheel (it's rotated ~10deg from correct) permanently. Fortunately I had a set of metal hexes I wasn't using so I'm not down & out and I can still use the messed up wheel with it's permanent hex when I want to run it.
  21. #101
    384
    Sounds about par for the plastic gears. Amazing how cheap a decent metal gear servo is these days though!
    Steering is nice and tight with a metal servo arm and bellcrank hey. Alloy c-hubs improve it too.
    12mm hexes are such a pain like that. I have to tighten the ones I have left every pack. I have one set of wheels however where the nut bottoms out to the shoulder of the axel and I can really crank them down metal on metal. That works really well.
  22. #102
    Apr 2019
    Miami, FL
    49
    I've seen a few people recommends the c-hubs - my only concern is about beefing up stuff too much and making it so more expensive stuff breaks, seems like this is a safe part though to replace? Any preference of brand?
  23. #103
    384
    Personally I think itís worth the alloy C-hubs, the plastic are really flexy. I use the Tekno driveshafts so the XO-1 alloy front hubs are really good there too. Plastic Tekno hubs in the rear.
    I think as long as you donít go alloy on the arms or shock towers? They seem to be the components that really lever on the diff cases etc?
  24. #104
    Apr 2019
    Miami, FL
    49
    Went out today to the track which, in its current state of construction, is an awesome bash spot and had some fun. Looking forward to heading back in a couple of weekends and tearing it up. I turned my BEC up to ~7.6v which the servo seems to like, it might be placebo but it does seem a bit faster.
  25. #105
    Jan 2019
    SF Bay Area
    807
    This thread had been dead for 2 months. It's no one else making any changes to their Rusty during the winter months? Sheesh...lol. Guess I'll have to "liven up" this thread.
    As you can see from the photo, I'm back at it again. Took my second Rusty (technically, it was just a 'rolling chassis') apart, and dyed the chassis pan black, just as I did on Rusty-Frankie (my first Rustler 4x4, which I recently finished "converting" into a 'true', race-ready, stadium truck. What does this mean? It means I'm finally getting started in my long-awaited/long-promised "other" Rusty conversion...the conversion I've eluded to several times over the past 6 months, but purposely not have any details about.
    Unlike my Rusty-Frankie thread, which focused primarily on the (almost) finished conversion (and, yes, there's more to come in that one, as a could things didn't 'work out' as I had thought, which means some "revisions" are coming soon), this will be a full/proper "build thread", from beginning, to end. Hope to have the thread created, and the first 1-2 posts, within the next week...hopefully within the next few days.
    ~ More peace, love, laughter & kindness would make the world a MUCH better place
  26. #106
    Apr 2019
    Miami, FL
    49
    I picked up a TRX4 Sport recently but brought the Rustler with me today to the park and promptly broke an a-arm at the pin... again. I guess I'll try the RPM plastic ones this time?
  27. #107
    Apr 2019
    Miami, FL
    49
    RPMs on order, should have them Tuesday. Hopefully they will hold up and not transfer damage elsewhere.
  28. #108
    Jan 2019
    SF Bay Area
    807
    Today, I didn't just work on one Rusty...I worked on both of them. First, I corrected some "problems" on Rusty-Frankie (and created a few news ones in the process. Today's update consisted of replacing the axles, getting rid of the axle extenders, and replacing a few Slash/Rustler parts work parts designed for the 4tec 2.0. To read more about the 'Rusty-Frankie' TRUE stadium truck conversion, check this out:
    https://r.tapatalk.com/shareLink/top...ink_source=app
    After getting some things done on Rusty-Frankie, I moved onto my other Rusty, 'Project Predator'. Today's work on this project involved prepping the wing mount for attachment to the rear shock tower, test-fitting some new axles (the same axles that ended up on Rusty-Frankie, although set is on its way), and reattaching the front & rear back to the middle. To follow this "our of this world" build, go to:
