Results 1 to 11 of 11
    Jul 2017
    245
    Worried about lipo battery
    So I had some fun in the river today with my trx 4. After I was done driving it I noticed if I shake the battery I can hear water sloshing around in it. How bad is this?
    Here's some pics from today's run.
    Victoria B.C Canada
    5,599
    If you have a bag of uncooked dry rice put it in there to pull the moisture out to prevent rust on the internal connections.
    Sent from my SM-G900W8 using Tapatalk
    Mountains cant stop me
    they have tried
    Jul 2017
    245
    Alright I will. It's a hard case battery so I just popped the case apart and dried off the cells pretty well. I'll probably plug the hole in the case so water can't get in it
    May 2019
    8
    What tires and foams are those? Look nice and soft.
    I epoxied my hardcase battery seams and lead hole. I think there's a tiny pebble in there still, I can hear it rattling. Will do well to keep water out also
    Jul 2017
    245
    Stock tires and foams from when the truck came out lol. I was worried that maybe the lipo needed to vent or something from the wire hole but I guess it doesn't. I'll seal it up tight for next time.
    After running in the river I took front and rear diffs apart and cleaned the bearings as well as all the portal bearings.
    Jul 2018
    East Detroit
    167
    My guess is the stock foams are toast, and thats why they look " nice and soft"
    Might want to take those stock wheels and foams apart, and switch to closed cell foam at least. The stock rim vents let water in, but not out. In a short time, the foam will just disintegrate since they never dry out. You could put drain holes in the treads, but they still wont last long.
    Jul 2017
    245
    Quote Originally Posted by Stircrayzy View Post
    I know they are full of water and the foams are basically gone at this point. Doesn't bother me tho as it still preforms the way I want it to
    Jul 2018
    East Detroit
    167
    That works MrJelly !
    I lost patience with wobbly tires when goin fast and had to pull mine.
    Jul 2017
    245
    If they get too wobbly I'll usually just squeeze the water out. I mostly do low speed trail and crawling with it so it doesn't really bother me.
    May 2019
    Michigan
    57
    you can get the water out of the tires by cutting little holes in between threads
    Jul 2017
    245
    Quote Originally Posted by Sharkbait View Post
    I've heard that before. I'm worried it will cause the tire to rip tho.
