Thread: Soldering?
    Aug 2017
    249
    Soldering?
    Is there any reason you canít use rosin core solder instead of silver solder?
    Eastern Shore, Maryland
    3,868
    Nope. It's just the rosin core silver alloy solder is better for electronics then rosin core lead solder? You just want to stay away from acid core solder with electronics. Then there's actual silver solder, and that's more of brazing than soldering.
    Aug 2017
    249
    Ok thank you.
    Aug 2017
    249
    So I just set my hobbywing max 6 end points. Now I have no steering most of the time and at times it twitches. Also I see in videos that the led on the esc should be changing to green mine donít am I doing something wrong??
