    Sep 2016
    124
    Replaced stub axle but now wheel is loose (has too much play)
    Hey guys,
    On my 4x4 Slash I broke the stub axle on the front left. Instead of purchasing a new one, I replaced it with a stub axle that used to be on the rear of this same Slash. Now the wheel has considerably more play in it when you hold and jiggle it. Here is my question, is there any difference in size between a rear stub axle vs a front stub axle?
    Thanks so much!
    Jun 2017
    Ohio
    1,256
    Quote Originally Posted by stilllearning7 View Post
    Hey guys,
    Thanks so much!
    Yes there is a difference. The rear stub is longer, that's why you are getting the play. You need a 6854x. Rears are 6853x.
    Feb 2002
    9,311
    nick is right, they utilize different bearings in their hub assembly
    front and rear stubs are not the same
    Sep 2017
    42
    I believe front are 6851X and rear are 6852X
    Feb 2002
    9,311
    this should clarify:
    Sep 2016
    124
    I appreciate all the helpful feedback and answers. That does help. My LHS apparently doesn't carry the stub axle for the front drive shaft. They carry the whole drive shaft. Would it be better to replace the whole assembly or just the stub axle that's broken? I'm assuming that I would have to order the stub axle online if I just replace that part.
    Indianapolis?
    14,129
    If your lhs has the whole thing, I would buy it. You can never have too many spare parts.
