Results 1 to 10 of 10
    Aug 2017
    10
    Traxxas slash 4x4 overheating problems
    I just got out my slash and hadn't used it in a little over a year. The battery had died. So I bought a new one and I tried a fifteenth brand this time cause it was half the price. This might be my issue... Well I've never really had an issue with it overheating before but I could only drive it for maybe 5 minutes then it stays blinking red and it feels extremely hot. Could I have bought the wrong voltage output or something?? I have a fan on there already but it doesn't seem to make a difference. Any help would appreciated. This is the battery I bought.
    Bias 35C 3S 5000mAh 11.1V LiPo Hard Case Battery UNI Plug (EC3/Deans/Traxxas/Tamiya) for RC Car, Truck, Buggy, Boat, Heli, and Drone https://www.amazon.com/dp/B01HUEJY0K..._HcW-CbVHBMR0F
    Aug 2015
    435
    Do the battery wires/connectors get hot? Are you using one of the adapters? I have heard bad things about these universal adapters causing excessive resistance. If you not worried about the warranty i would cut off the plug and use the connector for your esc.
    Aug 2017
    10
    I never even thought about the adaptor. That might be what's causing the extra heat. So you would cut off the tip and just fix the adapter on permanently?
    Nov 2018
    Spokane, WA
    191
    What are the names of the motor and esc? XL 5 and titan 12t?
    If so you can only run 2s
    If the car is a vxl model it will have a vxl3s esc and veilineon motor this should run 3s. I would check the gearing because who knows what the previous owner geared it at
    Aug 2017
    10
    It's 3s ready. I've anyways ran 3s in the past but with this battery in particular it overheats.
    Jun 2017
    Belgium
    89
    I think we need some more information about:
    - the ESC and motor you use (is it a Velineon combo) ?
    - the gearing you use
    Any idea about the temps on the ESC and the motor ?
    Do you have a fan on the ESC or on the motor (or both) ?
    Apr 2019
    40
    If the esc and motor are both getting warm and you’re using the same voltage battery, same gearing, etc, check to see if the drivetrain is completely free and nothing is binding up. I will regularly year a car down to the bearings to find a part that’s binding. Resistance through adapters and wiring will manifest as hot wires between the battery and esc. Good luck and happy hunting!
    Jun 2014
    Southern California
    7,486
    If it's been sitting for over a year, make sure all the bearings are good. Might as well check your gear mesh as well.
    Good luck and have fun!
    Indianapolis?
    14,139
    I personally would never run a 35c lipo. I have a 50c minimum. The battery may be holding you back. Do you have another to try?
    Jun 2019
    fox valley Wisconsin
    5
    first thing I would do after a year would be to change those bearings, and give it some maintenance. A 5 minute run that results in overheating surly is telling you something. bearing, clean dif and new grease. I've had old bearings lock up after just 2 weeks sitting in the closet.
