    Aug 2017
    251
    After market esc issue.
    So after I installed my new esc I canít seem too make the steering work. Any help is greatly appreciated.
    15,174
    Need more info. And, a vid would help
    Sent from my 5056N using Tapatalk
    Ya can't polish fertilizer...
    Aug 2017
    251
    I have throttle forward and reverse but when I turn the steering on the transmitter the servo donít even try to move.
    15,174
    What have you done to troubleshoot the issue?
    Aug 2017
    251
    Made sure the servo was properly plugged and seated in the receiver. Thatís about it at this point.
    Aug 2017
    251
    I just removed the steering servo and it seems like when I turn it by hand itís tough to turn it one way. Is this normal for a x maxx I feel itís not.
    13,326
    Isolate the problem. Plug the servo into Ch2 and see if it works. Plug the ESC into Ch1 and see if it works. If the problem follows the port on the receiver then the receiver is at fault. If it follows the servo then you've found your issue.
    Aug 2017
    251
    I tried switching it last night and the problem seemed to follow. I believe I found the issue. I took the servo out and took it apart and it smells terrible and has some moisture in it.
