Results 1 to 4 of 4
    Jun 2019
    Flex Cable/Motor Coupler
    Hi Everyone,
    New on the thread, need some advice. After I ran the boat a bunch, I did the required maintenance and removed the flex cable etc. Once ready to run again, I re-installed it and went out. Well I must have not tightened the flex cable to the motor coupler because the whole assembly now sits on the bottom of the lake. How tight should I tighten my new one to the coupler? How tight should I tighten the prop to the cable? Should I use a special nut on the prop? Any advice for this rc boat newbie would be great..tx
    Dec 2017
    Van. Island British Columbia
    835
    I crank the shaft collet pretty tight and have never had an issue, and the prop nut should be a 4mm nyloc nut that should be fairly snug and shouln't come loose especially on a new boat. Check them after every run and remember you still need to oil the motor bearings and grease the shaft every 3 or 4 runs.
    https://www.youtube.com/watch?v=FJj9wmKfIic
    Aug 2019
    Does the new shaft come with necessary hardware?
    Dec 2017
    835
    No part #5776 is just the flex cable nothing else and part #5777 is the brass stuffing tube with the plastic liner.
