Results 1 to 2 of 2
    Adjusting reverse behavior on the TQi/VXL-3S?
    Got my Rustler 4X4 VXL a week ago and man its a blast! Had some concerns about its behavior in reverse. First off it seems WAY too hair trigger and fast. I so much as tap reverse and it seems to go full throttle immediately. It also seems to linger on a tad when I let go. On top of that the front wheels by themselves tend to twist as if i am turning even though I'm hands off the steering. Are there things I can/need to adjust to make reverse behave a bit smoother. Ideally i'd like the same throttle progression as forward but maybe with just reverse speed capped at 50% or even less. No reason why it should just blast backwards when all i'll ever really need is to goose it away from a wall or something. Also want to make sure steering stays straight. No idea if that's a side effect of my Trim being pretty far clockwise. Gonna fix that soon. If not that, maybe a TSM thing? Been away from RC a while so still trying to figure out all the intricacies of this TQi and bushless ESC. I thing I've done already is order the bluetooth module so I can stop relying on the pushbutton/LED blink based menus to change settings..
    Jan 2019
    SF Bay Area
    478
    Just curious, but, is the reverse speed the same, shower, or faster than the forward speed. If faster, then your forward/reverse might be "swapped", in which case, your should reset & recalibrate the ESC & Tx. I don't remember the process, but you should be able to find it online (or call Traxxas, as I did, when my reverse wasn't working at all). If slower, or the same, them I don't know, in which case is suggest calling Traxxas. Traxxas' phone support is excellent...one of the best I've dealt with.
    ~ Coming to you live, from somewhere on planet Earth.
