Results 1 to 14 of 14
    Dec 2018
    6
    Xmaxx v2.0 Mod 1.5 spur and pinion.
    So.. after many, MANY 54t (4 pcs), 50t (1pcs), 48t(2 pcs) spurs and 18t (lost count) pinions later.
    Im frustrated.
    Guys, please help. Truck is great. i bash it alot and i love it, it takes it all but spur and pinion are not cooperating with me.
    xmaxx v2, hw max6 esc, 70c constant batteries, else is stock.
    Any advice on 1.5 mod on xmaxx ? stock motor still runs great so 5mm shaft is still good.
    Gearing should be same as 18/54, can be 18/50 also.
    Anyone here have done this ?
    Where should i turn to get one set ?
    Thank you.
    Silver
    Oct 2016
    4,021
    You need to ditch the pin system, and learn to set the mesh manually. You can use 1.5 if you’d like to, but you don’t need to.
    Somehow builds are never done....
    RC Champion nickruger's Avatar
    Jun 2017
    Ohio
    1,162
    I agree with Grip. There is something else going on. Not blaming you, but most people ditch the pin system and don't have problems if they properly set the mesh without them. I run plastic spurs on stuff running 6s for months, set the mesh bad one time and the spur pulled a Nicholas Cage and was Gone in 60 seconds. It's all about mesh. Mod 1.5 is overkill for that setup and you can still screw mod 1.5 up with bad mesh. GDS makes good mod 1 gears. Looking back that's what I would of went with. Fastlane Hobbies has good gear selection and if you do Facebook B and M racing makes awesome mod 1.5 gears. They are 80$ for a spur and pinion.
    Aug 2017
    247
    I run a harden steel spur and pinion on my x maxx.
    Oct 2016
    4,021
    Since were sharing. I run a hardened GDS 46 tooth spur(1.0) and a 37 tooth hardened spur.
    May 2009
    40
    Quote Originally Posted by nickruger View Post
    Hard to find mod 1.0 pinion on 8mm motor shaft. Wonder why that is?
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    May 2009
    40
    Quote Originally Posted by Gripdog7205 View Post
    What kind of speed are you getting with that gear.. Also what tire are you running these days?
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    Oct 2018
    Quote Originally Posted by IamRevoMaster View Post
    Sagacustomrc has mod 1 pinions in 5,6 and 8mm. Here are the 8mm pinions https://www.sagacustomrc.com/store/p...ons_gears.html
    Sent from my Pixel 2 XL using Tapatalk
    Jun 2017
    Ohio
    1,162
    Fastlane has some lower tooth counts too.
    http://www.fastlanercs.com/pinions---spools.html
    Apr 2018
    SE, Wisconsin
    23
    6s xmaxx since 1st shipment,now 8s harded drive train.still original 18 pinion,54 plastic spur,made a thin shim to put under mounts an using pins that way. Other wise gear mesh way tight.(vehicles should coust well in neutral).
    Oct 2016
    4,021
    Badlands and a conservative gps number is 61 mph. That was in the hood. So, no all out runs. It does quite well.
    May 2009
    40
    Got it Thanks G8eraid
    That's enough speed for me to sendit. thanks
    Thanks nickruger
    Last edited by Double G; 06-20-2019 at 06:38 PM. Reason: Merge, use edit button to add more info
    2-REVo 3.3
    1 summit
    2-XMAXX
    And many others
    Dec 2018
    6
    Okey. i got my point. i bash it way too hard then. E-Revo 2.0 altho takes it all.. only regular maintance and good to go.
    That's why i thought that spur and pinions are weak spot.
    On e-revo i took guide pins out and shimmed it using paper. Still good.
    On xmaxx .. whatever i do.. it keeps destroying itself.
    That made me wonder.. what do i really need ?
    GDS hardened steel mod 1 .. okei, are there any suggestions on pinions ?
    I love gear ratio 18/54 but IF IT HOLDS it can be 18/50 also but not any faster. That thing is a beast with max6 and on 70c 8S
    Cannot compare to original 25c batteries and original esc.
    Thank you.
    Silver
    15,174
    Bad mesh is why the gears break.
    Ya can't polish fertilizer...
