Results 1 to 12 of 12
    RC Qualifier atoms's Avatar
    Feb 2004
    Virginia
    367
    Mini Revo VXL - Stripped Servo Gears - Replace gears with metal ones?
    Or get a whole new servo with metal gears?
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,561
    Metal all the way. Not sure if they offer a gear upgrade to metal. Or if have to swap servos. But going to metal gears will help.
    I got my Merv used already had a savox mg on it.
    Feb 2004
    Virginia
    367
    I was wondering if the 2080X (metal gear version for MERV) servo gears fit in the 2080 servo as a replacement.
    It's $18 for the gears and $44 for the whole servo.
    Nov 2018
    Spokane, WA
    695
    I believe that the x model servo would have a stronger motor there for it would be better to get the 2080x instead of replacement gears for the x model
    Correct me if Im wrong
    Jul 2018
    beaverton oregon
    1,561
    In looking some online. It looks like the 2080x gears should fit into the servo.
    I'd go for swapping gears. If issues after perhaps try a savox. Sw-0250mg. Has 69.0 oz tourque
    Feb 2004
    Virginia
    367
    Quote Originally Posted by Overpowerxmaxx View Post
    Correct me if I’m wrong
    I feel like the 2080 is plenty strong... it's just the gears that are terrible!
    Feb 2004
    Virginia
    367
    Huh the savox is only $11 more than the gears... which I'm not even 100% sure will fit....
    Does that Savox have the reverse steering issue?
    Thanks!
    Feb 2004
    Virginia
    367
    Huh.. the amazon reviews on that Savox are really good... might just do that!
    Jul 2018
    beaverton oregon
    1,561
    I've had no issues with the savox. It was a easy direct plug n play for me.
    Something you could also do that could work in the mean time is if gears are stripped only in one area can rotate gear 180 put back in and it may work fine on the good teeth. But just depends on what gear is bad and where.
    Feb 2004
    Virginia
    367
    Just ordered 2 of the savox servos... I'm going to replace them in both my revos and sell the old servos on ebay.... THANKS!
    Feb 2020
    5
    The metal servo gears (2080X) are a direct swap out for the stock 2080 plastic gears.
    Dec 2019
    Denver, Co.
    15
    I swapped out the servo with a Savox when I first got the car. Runs great, the only thing you need to do is reverse the direction in the transmitter
