    Jun 2019
    14
    Exclamation 4x4 INSANE wheel shaking and speed wobble
    So, I've had aNOTHER problem with my slash. With the wheels suspended, at around 3/4 throttle the wheels get to max 'pizza cutter' status, and half a second later, my slash starts shaking like there's a 100 richter scale earthquake. Also, at around top speed, it gets into ANOTHER feedback loop, where speed wobble exponentially increases to the point of fishtailing till the speed decreases. I'm running stock, velineon motor and esc, regular TQi receiver, and a 3K maH 7-Cell NiMH hump.
    13,661
    Standard ballooning of tires which causes less of a footprint on the road. You could balance them which will decrease the vibration.
    Dec 2017
    North Texas
    630
    As Double G mentioned balancing is a good idea.
    If you are looking to go fast often then you may want to consider some wheels/tires built just for on-road speed.
    These are grippy and belted just like your 1:1 car tires. They are rated upto 160 mph (not scale speed)
    It will require you to adapt from the original wheel hex to a 17mm hex. (plenty of aftermarket available for that)
    https://www.hobbyheroes.com/collecti...es-grpgtx01-s3
    May 2019
    Wisconsin
    25
    Is there dirt in your wheel?
    My old badlands used to do this very badly and i read that dirt can get inside them and unbalance them.
    i took them off the wheel and sure enough, there was a lot of dirt in them causing the truck to shake violently at high speeds.
    some people drill/melt little round holes in them to fling all the dirt out.
    Jun 2019
    14
    Hey, sorry i've been gone for a while, but thanks for all the good tips! The only reason i haven't melted a hole, is because i have road tires now, not quite as ballony as the stocks, but if i drill holes in the stocks or the road tires, won't more water get in on wet runs?
