Results 1 to 11 of 11
    Jun 2019
    4
    4x4 ruslter vxl axles
    I would just like to say that it sure would be nice for traxxas to fix this problem I cant run this thing 5 times without breaking the junk axles traxxas put on this thing oh I could upgrade them for about 70 dollars for the rears and another 70 for the fronts but from what I've seen even they are junk very unhappy with my first traxxas and most likely the last
    Indianapolis?
    14,139
    I'm sorry that you are having a hard time. Could you please describe the battery and how you drive your truck?
    Nov 2018
    Livermore, CA
    187
    I’ll get the popcorn
    I’m not a heavy basher but my one rustl4r vxl still with stock everything set up runs mostly 3s and has even lived for a while with 4s running the UDR motor and esc.
    Indianapolis?
    14,139
    My daughter has had her truck for many years. It has the O.G. El Sob special motor system in it. It runs 2 and 3s lollipops its whole life and it still retains the original CV axles.
    RC Qualifier tmbold's Avatar
    Oct 2014
    Louisiana
    347
    I beat the snot out of mine on 4s and have never had a problem
    Jun 2019
    4
    It is completely stock running 3s 6400 mah it's funny that you all say you have not had any issues but a quick Google search and this is very common I must just have bad luck because I run this at my work in a field and travel parking lot and have gone through 3 rear axles in the month that I have had this thing idk should've bought something else
    Oct 2014
    Louisiana
    347
    Jeff,
    Iím curious, is this your first rc? Just curious, if not what else have you had
    Nov 2018
    Livermore, CA
    187
    At the price point any other 4wd stadium truck, or 1/10 rig in general, is going to break as much if not more than the 4wd Rustler from what you are describing.
    Make sure your slipper clutch is not too tight, the jolt of a 6400mah 3s battery can deliver quite a twist on takeoff and deceleration.
    Feb 2019
    Texas
    79
    I agree with this advice! If you're putting down too much torque, loosen the slipper clutch to absorb it.
    Jun 2019
    4
    I adjusted slipper clutch tightened all the way down then backed it of 1 and 1/2 turns I will back it off another 1/2 to 3/4 of a turn to see if that help thanks everyone for the input I appreciate it
    Jun 2019
    4
    After doing some research it appears that I had the slipper clutch adjusted fine if anything it may have been a little loose so that doesn't explain why the axles keep breaking at this point I don't know what to do other than upgrade to the tekno axles and see what happens
