    Jan 2015
    21
    Mamba X - Red Blinking Light, No Sounds, Not Arming
    Swapped my (working just fine) Mamba X / 2400KV system from one Slash 4x4 into another, and now, the ESC does not arm (no sounds / beeps), just sits there, with a red blinking light. According to the manual:
    ** Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0. **
    I've reset the TQi radio system, checked TraxxasLink, and throttle is set to 100%, sub trim to 0.
    I'm plugged into receive channel 2, the correct way.
    If I plug the ESC into the second channel 1, it arms fine, and will drive the motor, albeit while turning the wheels.
    It almost looks like channel 2 is toast on the receiver, and yet all the other channels work fine. Just prior to putting the mamba x combo in, this same receive was running an SW4 with a Hobbywing motor.
    Anyone have any thoughts as to what I'm doing wrong? Thanks!
    Jul 2017
    221
    I've had the same thing happen. It was the channel two on my reciver. Had to get a new receiver
    Jun 2017
    Ohio
    1,161
    Yep that sounds typical of a reciever failure. Do you have another reciever you can test it out on just to confirm. I swapped out a servo once, everything was fine when I took it apart. Put it back together with new servo and reciever was dead. Who knows.
    Jan 2015
    21
    Yah, I swapped in an old 3 channel receiver and the mamba works fine. Going to order a replacement. Thanks for the feedback.
