    Jun 2019
    Summit 1/10 Tyre Problem
    Hi All,
    I am a newbie in this forum, and I want to apologize to anyone if a similar thread was already posted. I have just purchased a second hand Summit 1/10 and I think there seems to be a problem with the front left tyre. The tyre is turning kind of in an idle position. I mean, it is triggered but it does not rotate as the others do. Do you have any idea what the problem is? I disassembled the tyre and looked it over. Nothing unusual.
    Thank you very much in advance for your valuable recommendations.
    Ersin
    Sep 2009
    3,592
    1) is the axle leading towards the tire rotating but the tire does not. Then its probably a stripped hex nut or a strip wheel hub (wheel hex). Remove the wheel screw and take a look
    2) if the axle leading to the wheel does not rotate under power than your diff lock is not engaged or the differential geaars are badly stripped.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Jun 2019
    Thank you very much for your detailed explanation, I will check it out and get back. Thank you once again
