Results 1 to 11 of 11
    Apr 2019
    89
    I think I'm done with this build...
    Hello...
    I think I'm done with this build, but if you see something you think needs to be improved, give me some advice. I just put an aluminum servo saver on here. Kind of hard to fit everything, but works really nice. I stuck with some plastic, to give a little flexibility.
    https://ibb.co/LpLBFJY
    https://ibb.co/9WwdNBh
    https://ibb.co/DRqTHMt
    Oct 2016
    4,122
    Not even close. Iíve said similar things for years.
    Somehow builds are never done....
    RC Champion FnFancy's Avatar
    May 2016
    Los Al California
    1,652
    Haha, done!? Maybe for now, eventually something will break and then it gets upgraded! On a serious note, a beautiful rusty you've got there, almost too pretty. Go out and thrash that thing. If you don't break something, you're not having fun!
    Apr 2019
    89
    Love you guys on this board. I learn so much.
    Dec 2016
    195
    Looks great!!!!
    I was done with mine $500 ago as well....
    Apr 2019
    89
    Yep... You guys are right. Going to get some 12 mm to 17 mm adapters and some grip tires. This thing is geared for speedruns. I've got a 33 tooth pinion and 76 tooth spur gear on it. 3s lipo should get me going pretty good. Any recommendations on adapters and tires?
    May 2016
    Los Al California
    1,652
    It's hard to tell, are those mip axles? If so, go with hot racing adapters. Tires for speed runs I'm not well versed on. Some one will chime in with the necessary knowledge I'm sure.
    Apr 2019
    89
    Those are Traxxas drive shafts.
    May 2016
    Los Al California
    1,652
    Then just stick with the traxxas 17mm adapters. I can't really see the drive shafts, are they the stock plastic ones?
    Apr 2019
    89
    Sorry, man. Those are the Traxxas heavy duty steel drive shafts with the rubber boots.
    May 2016
    Los Al California
    1,652
    Quote Originally Posted by OtisWhitestone View Post
    Perfect, then definitely stick to the traxxas 17mm conversion. I have them on my rusty and never encountered any problems. Well, just make sure to locktite the barrel nut and check every so often that it's still tight.
