Results 1 to 4 of 4
    Jun 2019
    5
    Aton battery question
    Is there a setting in the telemetry or something that i can adjust so the drone doesnt return to home so soon.
    The radio says the battery has died.. and does the return to home.. i have a 5000mah pack in the drone.. however.. when i charge the battery.. its only about 60% used.. my charger only puts back about 3000mah into the pack..
    Thanks
    Hello all, new owner here.
    Second flight yesterday, had only flown it for 10 minutes from a full charge, climbed to about 70 ft, then my Aton + just shut down and fell, smashed into the ground breaking off two arms and cracking the upper and lower body, sending it in to see what the issue was and they said they should either be able to repair or replace.
    Glad i didnt have the gimbal or a camera on it.
    Dec 2017
    Quote Originally Posted by dgrobe2112 View Post
    Thanks
    You likely have a bad battery. Same thing for me. Is your battery puffy? Have you used it much or has it just been sitting around? They'll crap out after a while if they just sit and never get used. It's probably charging to full capacity, but that capacity is now greatly diminished.
    Dec 2015
    467
    The Aton estimates battery level so if it comes home premature, your battery is either bad or not a full charge. Either way, you don’t want it dropping out of the sky before it gets home. Better safe than sorry you knocked a hole in the neighbors roof.
