Results 1 to 13 of 13
    Jun 2019
    21
    Slash 2WD Differential Grease
    Just wanted to check the grease goes outside the main gear, and I wanted to know what to put inside the main differential?
    Sep 2012
    Hammonton Nj
    705
    silly putty
    N. Idaho... Da Sticks!
    7,574
    Quote Originally Posted by Role View Post
    silly putty
    That's good if you want it limited-slip.
    For normal running I use Associated Black Grease. It coats well, stays on, and wipes off easily when performing maintenance. You don't need that much, just a bead right down the middle of the gear; and excess will just get slung into a corner of the transmission.
    Jun 2019
    21
    Thanks for that
    Sep 2012
    Hammonton Nj
    705
    plumbers putty works good too
    RC Champion zedorda's Avatar
    Sep 2015
    S.E. Michigan
    1,037
    A spool would be cheaper and better in so many ways over whatever you can think of. But will be the worst possible choice for function.
    I use Red"N"Tacky from Lucas Oil products been great for years.
    Aug 2019
    11
    I recently rebuilt the diff in my race Slash, and at the advise of one of the other local racers, used Lucas Sticky red, I did notice improved performance.
    However, I would think that even that thick red grease will eventually get tossed, I just don't know how frequently.
    However, packing my diff with that did make a difference in my truck.
    Sep 2015
    S.E. Michigan
    1,037
    Quote Originally Posted by Geiper Racing View Post
    I hope you are not saying you filled the inside of the diff with grease. Because you are supposed to use silicone diff fluid inside and grease on the outside and just a thin film on the ring and pinion.
    Jun 2017
    357
    @zedorda
    Correct me if Iím wrong, stock diff isnít sealed so if we use silicone oil it will leaks. I am using silicone oil with hot racing differential.
    There are some instructions for sealing stock diff..
    Jun 2016
    North Jersey
    657
    yes, he packed it and the factory diff is NOT sealed so you can't run silicone oil in it.
    Aug 2019
    11
    UH, yes it is packed with grease.
    The stock housing is not sealed and the "fluid" will leak out.
    You should try it sometime....
    Aug 2019
    Woodstock, Ga
    26
    I use a grease called "grim racer". It's used for marine prop shafts, it has excellent anti-sling, and is for high rpm applications. No problems with it. Everything inside the trans case gets a liberal coating.
    Sep 2015
    S.E. Michigan
    1,037
    Quote Originally Posted by alexsasax View Post
    @zedorda
    Correct me if I’m wrong, stock diff isn’t sealed so if we use silicone oil it will leaks. I am using silicone oil with hot racing differential.
    Yes you are completely right. I had been posting in the Slash 4x4 section and forgot where i was sorry.
