    Jul 2019
    Slash 2 wheel drive gear box problem
    Hi so I have a problem with the gear box. Every time i pull the trigger the car doesn't move and the motor and pinion gear are attached very well. I have been able to use the truck for 2 weeks ! I need Help ASAP!
    Hammonton Nj
    710
    sun gear broke, or strpped spur gear, or top gear pin
    13,532
    What is moving and what is not? Once you figure that out you found where your problem lies. Don't be afraid to open the gearbox up if necessary - nothing will spring out. Use the exploded views that came with the truck.
    May 2007
    Endicott, NY
    738
    Check for a spun wheel hex then make sure your wheel to outdrive connection is solid. If so check for loose or contaminated clutch. If that is ok then you have to open the transmission and check for stripped gears. If they are OK then you may have a broken layshaft pin.
    trinity 6cell packs - 5 cells for the price of 6!
    Aug 2019
    11
    One step at a time---
    Take the gear cover off and see if the spur gear is spinning?
    After that, are the axels turning?
    Process of elimination...
    Good luck
