    Jul 2019
    Tires for slash... Help!!
    Does anyone know can i put 3.8" Proline Trenchers on my Slash? and by fit i mean the hex adapter size mine is 12mm but i can figure out what the Prolines are.
    RC Qualifier MAC FAB's Avatar
    Apr 2014
    So Cal
    787
    Wheel offset and tire diameter may be an issue. Standard sc tires are roughly 4-1/4" tall, so at 6.65" tall and basically 4" wide and a 1/2" offset, the larger ones will probably rub the chassis, both front and rear without even steering. Not sure if running the wide arms would help, either. 17 mm hex adapters are readily available, but these will be heavy, so the rear axles and the steering servo will get a workout should you be able to shoe horn them on there. People run the 2.8s all day long for what its worth.
    N. Idaho... Da Sticks!
    7,477
    My 3.8 E-Maxx tires will not fit on my Slash at all, they hit the chassis before the hex even gets close to the wheel.
    You really don't want that size of tires on a Slash, 2.8s are hard enough on the chassis, suspension, and motor.
    RC Qualifier Synnergy's Avatar
    Jun 2017
    Orygun
    872
    The bigger the wheel the more stress you put on the axles. I used some 3.8s but they kept bending axles (T=f*L). I wouldn't suggest that big of a wheel/tire with stock axles...bummer I know:
    These were too big...but these:
    are the perfect size IMHO.
    MTFBWY
    Apr 2014
    So Cal
    787
    If you're going to go 17mm hex with 2.8s, look at AE DB8 General Grabbers. I'll throw them on my Slash for a pic.
    20190712_180013 by MAC FAB, on Flickr
    20190712_175953 by MAC FAB, on Flickr
    Sep 2012
    Hammonton Nj
    676
    2.2 proline sand paws are great. all my cars have them, they dont balloon much , last a long time
